cappuccino34
At a cadence of 60rpm with a 34 tooth front ring your chain does a revolution in just over three seconds.It does it in every gear but is more noticable when I pedal with low cadence, low shift (9+). The skipping repeats every 3-4 seconds with cranks everytime in different position (3-4 pedal rotations).
I will try the chain but the "click" & skip comes from the motor itself - I am almost positive about this cause you also feel it in thru the pedals.
I think that's your answer.
Maybe get someone to watch the derailleur cage to see if it 'kicks' when you get the skip.
