Stephen B
If you can do 600w you are more of a stud then I thought.
In turbo mode too!If you can do 600w you are more of a stud then I thought.
I did max pedaling just for a few seconds in full boost power mode.How long can you maintain that high of an power output?
Are u meaning calories burned?I did max pedaling just for a few seconds in full boost power mode.
1. Miranda FB connecting rods really suited me, they are a little wider and I like it.Wow so light. If U have pictures when weighing pls share. What components use?
So, one can put the power mode to "0" (not off which then the motor is decoupled and then it's just human drive train only. Then measure watts and calculate power output...if one got the power meter pedals, it would probably be more accurate and the just do the calculation automatically. But they run $500-$1500, so yipesPower is measured in watts, for instance Peter Sagan is the strongest cyclist ever , I think during a tour of Italy sprint he maintained around 440w for 20 minutes and in another peaked at over 1400w
Whoops. Looks you can hit cadence and watts modes in 0 power mode but no metering like you said. But it's does do the speed, trip etc. I just checked in the bike stand now.Should not read anything with the motor off. Again it is reading the power used by the motor. Unless the motor acts like a generator...
Francis is the "Man"!Francis is the owner of www.MTBR.com
Nice.Yesterday torture ride, this CEF50 and Bafang M820 ride flawlessly. Arrive at home with 16% battery left.
Head to head climbing with Shimano EP8 at 24% gradient 😍
Bafang M820 use level 4 of 5Shimano EP8 use trail levelyoutube.com
Did you mean carbon seatpost? I never heard of carbon dropper post.The saddle and dropper are carbon fiber
The shortest dropper is quite light as well. I don't use it on road, so for a 100mm dropper, the weight savings is quite significant.Did you mean carbon seatpost? I never heard of carbon dropper post.
There's a significant weight difference between a carbon seatpost and a normal dropper post.
when your height under 170 no problemThe shortest dropper is quite light as well. I don't use it on road, so for a 100mm dropper, the weight savings is quite significant.
The pin is lighter than aluminum by 100-200g.Did you mean carbon seatpost? I never heard of carbon dropper post.
How many percent of the motor power did you use?Yesterday torture ride, this CEF50 and Bafang M820 ride flawlessly. Arrive at home with 16% battery left.
only using maximum level 4 with 70% motor powerHow many percent of the motor power did you use?
This is a very good indicator. Now I also wanted a 720W batteryonly using maximum level 4 with 70% motor power
bike is light, but backpack heavyThis is a very good indicator. Now I also wanted a 720W batteryI'm tired of carrying a spare battery in my backpack
Yes. I think it's better to buy a ready-made battery. And melt the heavy body into wheels.bike is light, but backpack heavy. Will make DIY 720W battery?
He refers to the old Bafang Go App. This is working with my 245 Display as well. But no option to adjust levels etc..No he says Go app...
That is just the title of the thread.
