I think the bottom using 22. Just grind it until it fitted.
when I inquired what size bushing to get, Jean confirmed with their engineers to get 22, not 22.2. Look back in this thread... we debated it as the opening in the specs is 22.2. I ordered 20... will see if that works when I get my frame
I use default FOX DPS bushing from Polygon Siskiu and direct fits.
I posted, in the spec thread, a diagram from the SZZS engineer that clearly shows the bushing as being 22.2
I think the Float X should fit. My MegNeg is as thick as a coil unfortunately.
How wide is that body from the megneg?
Im not sure if i have enough space to fit one.
Today the Nukeproof/token headset arrived.
For the remote plug (dp e181) to fit the plastic in a whole needs to be trimmed a lil, apart from that it fits OK.
I’ll take advantage of disassembling and route cables better, add some noise insulation and upgrade the shifter to xt.
Also upgrading the fork to a lyrik for stiffness
any picture or video?
70k, quite thin but either way 4hrs riding for me was impressive!
Next test will be using mid-level the whole ride, stay tuned for tomorrows report :p
Hey, I think you owe us the mid-level report. 😃
Km's and elevation gain in second level, please! :p
Once I finish the headset + some noise reduction on cables i’ll be able to ride it again!
Sorry its half assembled now
I am having my Fox Float X2 210 x 55 stroke reduced to 50mm. It has one volume spacer in it now should I have them leave it in?
I don't feel comfortable taking the shock apart myself.
Leave it. Adding or removing a volume spacer is a job that doesnt even require tools
I got it.. I just pulled out the 720 wh battery and it’s significantly heavier than the motor or the frame… kind of wish I went with a lighter battery
Anyone know if we need a special chainring tool to tighten it? I’m not sure I received one if so..
Part c and d?
Hey so it is 22.2. Linda had me scratch the paint off the frame and it fit.
    Join 43,170
