Just a quick comment on how this compares to building a carbon frame.
I just built up a 2024 Canyon Strive Full Carbon emtb from scratch. To fit the chainstays and seatstays was pretty tricky - everything requires a bit of movement / bending and pulling and to align everything for the bolts to pinch down straight. There's probably 0.3-1mm or so difference in the finished carbon product compared to the CAD, which means when building it it just doesnt quite line up properly without some kind of intervention (eg, using human force to fit it!).
In stark contrast, the Pole fit together like a dream, everything was in perfect alignment. No bending, pushing, pulling at all, it all goes together like a perfect fit. The axles line up perfect, the big oversized bearings and bolts all aligned perfect and bolts pulled through like a hot knife through butter... It was actually a really pleasant thing to assemble.
Thats the difference between a computer building a frame to 0.1mm tolerance and a human laying up a carbon frame to some kind of guide and everything being *almost* in place, but not perfect.
The end result is that the canyon will place different loads on the bearings / pivot points at different stress levels and will likely require more frequent maintenance (especially on the smaller bearings) where as the Pole will have lesser stresses places on these areas, and the bearings will most definitely perform better for longer (and they are much larger bearings too).
The Pole suspension will also be able to perform at near 100% as design, and the Canyon will likely not quite be quite as effective (95%?)
