Bafang m510
Thats the reason I ordered @ Chili Shen! Great Motor! Did You try low battery levels? Is there power decrease below 20 /10 % SoC? I run down to 32% today, no power reduction so far…
with firmware 14F801010.1 power decrease under 30%, with firmware 14F802010.1 under 10%
Quick review of my first round with new M510 V2 today. I‘m really happily surprised, looks like Bafang finally can compete with the big brands in regards of motor behavior. No cutouts, and a very natural feeling, translating Your pedal input into power assist. They renamed the 5 modes to Eco / Trail / Sport / Sport+ / Boost. I used Sport and Sport + today mostly, and even at really steep climbs You get enough assist in Sport mode if You increase pedal force. I like it. Noise level unchanged. I think they changed the torque sensor, the Calories counter is back on my new DP C245 display. The handlebar controll unit is nice and slim. Overall, I‘m happy!
So in V1 I can only change the torque sensor and make V2?
So in this case, the question is still valid, can we change the controller and make a V1 into a V2?
Chili said it can, but no stock for FC 2.0 controller. Or maybe if anyone have close connection to Bafang person can confirm again.
Who knows the exact name (partnumber) of the controller in version 2? As I know from the M600, the new controller will be available for sale in a while.
Firmware upgrade was successful. Did You ever play with the Besst Pro parameters? What Did You change? I see multiple options, but I have no idea on what to change / what will be the effect of startup angle / acceleration etc. Some advice?
Hi guys, a couple of questions about M510 v2. Can you calibrate the torque sensor with the BESST tool? Does the Bafang Go + app. connect to the DPC245 display? Thanks.
Tried to connect my DPC245 display to Bafang Go+ app - Display was detected but connection not possible
this is my setting
U can download DP C245 manual. It said DP C245 equipped with Bluetooth 5.1 can be connected to the Bafang Go+ APP
Hmmm…my Display does not connect. This would mean no BT 5.1. Is this a software issue, or different hardware? Can it be updated?
If you do some trial things, such as jumping on the spot with the brakes applied, it might be worth increasing the startup angle so as not to put too much strain on the motor and brakes.
Is this new M510 v2 the same as FC 02 ? or a different new model ? Whats this motor designation sticker reads? This new renamed 5 new modes are probably software updates or Is there a change in the hardware? Like the torque sensor?
Tks,
Caio
    Join 43,130
