Loading bike into the Van.
These are the runners about £80 from e bay, I have 2 sets one for the bikes and one kit.
I’ve covered that already……..! Seriously though if you can’t get your bike into the van then you’re gunna be a danger to yourself on the trails and I would consider doing something else!
My Toyota super custom van is about 2-3 feet taller than me. I'm 73KG 😂 There is no chance I could lift 25KG of bike onto to a roof rack on a hi ace super custom. If you drive a mini then maybe 🤣
Not sure how that translates to being a danger on the trials either 🤣
These are available singly or in pairs, in various lengths. I use a 5’ one for my electric unicycle (49kg) - one half slides inside the other, and is secured either open or closed position by a ball detent. I know this won’t solve your front wheel issue, but it’ll get the bike into the van, from where you can remove your wheel and store as you see best.
You can do a lot with some simple bits of timber.
Something like a 8" wide strip of MDF, with 3x2 'sides screwed from underneath and a block of timber to be a 'shoe', with an appropriately placed 15mm hole through it for the axle bolt.
Wheel off, place your block in the forks (the heavier lower part would swing to the bottom as you rotate the front into the 'slot' ) then shove it forwards. If you make a decent job of it the bike will stand up steady whilst you get a strap or something on it for driving.
That said, if you're a VW T6-dweller you probably want some Gucci emperor's New clothes affair that's actually shit and costs a fortune when a few bits of timber would be perfect.
But, hey ho, I tried. :-D
I’m looking for some ideas.
I have a weak lower back and hefting the bike into the van, rear end first, can be a bit jarring.
I’d like to connect the fork to a fork mount and then lift the rear of the bike and slide it into the Van fork first.
I have a VW T6.
Is there anything commercially available that does this?
I'm struggling now as I'm getting older
I have a VW T6.
If you're willing to spend a lot you'll get something. Easy option is to take battery out and wheels off. I have a chest high rack and finding it harder as I get older its very easy to tweek my back etc.
The downside on doing that is that you would have to step up into the van, lifting more weight (unless the bike is heavier than the rider) and hunching you back 😫
I have a VW T6.
Get a scaffold board and ride the bike into the back of the van ( keeping your helmet on at all times)😂
Check out Tom Cardy van.
May give you some ideas
I personally use Bikestow in my VW , I too have a dodgy lower back which I try to protect as much as possible. I find leaving the wheels on is much less of a strain on my lower back, I simple roll my bikes in backwards, yes you have to lift the rear, but since the weight of bike is supported by the front wheel it's a easy on my lower.
Hope you find a solution that suits your needs
I use these, but placed sideways, with sliding fork fixtures,
View attachment 108449 View attachment 108450
Hi B1rdie. I have a Ford Torneo Connect van that has seats in the back, but they can be folded down, but it does mean there's limited height. I'm wanting to try and fit two new e-bikes into the back of my van the way that you have with the front wheels removed and fastened to a system like yours. I would love to get some more input from you on how best to make something like this, lessons learnt and things to avoid, how you secure the back of the bike, and how you get the bikes in and out of the van etc.
Mine also has to be able to be removed all the time, because, as I say, it will be on top of the folder dunnage, so it can't be a permanent fixture. I'm looking for something simple that can just hold the front wheels, with maybe saying else for the back wheels to just ensure that they are stable, and maybe just use a normal back wheel cradle- but would love your input.
Thanks in advance.
Lance.
Thanks in advance.
Lance.
Hi Lancelot. Sorry for the delay. I have found no need to fix the rear wheel at all, even after having hit a few speed bumps already. The side ways sliding rail with a front axle fixture from aliexpress works just fine, but I would add also a front-rear sliding system to adust to different fork designs and consider the use of front mudguards, in order to avoid hitting it with the tailgate or not being able to turn the handle of a some front axle because of lack of space...
Thanks Birdie! I cant have a permanent setup and I cant fix anything into the van as my van is also a people carrier with seats that fold down so I will be putting my bikes standing up on top of the seats. I am looking at using a plank about 30mm thick and 240 wide and 500 long to mount the front fork holder to. I will then take off the front wheel, fix it to the fork holder mounted into this plank, and then lift this up and slide it into the van from the back (front wheel with wood plank first). This will give me a bit of lateral stability but as it is not fixed I will use a simple back wheel stand I bought as well for the back wheel. When I have two bikes, I will connect their two wooden planks with a bar, so then I will get even more lateral stability. Hoping this will work and looking to make it in about 3 weeks time...
That will not be stable but worse still the bike will not be secure in the event of an accident. For a single bike your best bet is mounting the bike on a fork mount secured to the floor at the rear of the vehicle then if the bike is too long to fit between that and your rear seats you would either have to remove or tilt the seat. If your only option for that seat is to fold it flat you may have enough headroom to rest the back wheel on it with saddle slammed or if not it means removing the rear wheel.
If you will load the bike with the fork towards the front of the van, then the rear wheel must be tied somehow or the bike will kick like a rodeo horse 😊. With the front axle secured, its possible to tilt the rear end sideways quite a lot, making it easy to arrange for more than one bike.
thanks for that B1rdie. I will be using a ratchet to go from a metal load loop on one side of the back of my van, around the first bike bottom of the seat post and then to the next bike bottom of seat post and then down to same metal load loop on the other side of the back of the van. So this should hold the backs tight. Also the 500x240mm wooden plank the front forks will be attached to (one per bike) will be up against the back of the front seats, so they bikes can move any futher forward and their backs will be tied down as explained. so hoping with this they will be steady...
