The New Official BLEvo Thread
I use the Ebike Field.
Gives me Battery% , Power Mode, Cadence, and user power.
there are others, but I have not tried them
Well that's cool. I see Specialized also have a pretty basic app. Thanks!
But!, I'd still love to see skins and themes for blevo :)
Just realizing my 2.0 I purchased a while back for my levo with mastermind wont operate blevo or levociraptor apps? I didn't want to install it immediately on my new bike. Installed it in my ride but now cant remove it or anything until this Christmas surprise in unveiled, am I mistaken? Thank you all.
Levociraptor 2.0 should work with Mastermind TCU and Blevo App. But you do not get smart power control of the motor like Blevo with LED TCU. I swapped out my MM TCU for the LED TCU and it all works perfectly. OP has reportedly gotten the MM TCU to work and has basically promised an update in the near future. I hope so.
Thank you for your response and time. When I attempt to connect the blevo it searches for and finds but then sits there saying "waiting for discovery services" for a loooong time. I've always stopped it after 5 or 10 min. Not sure what to do?
I've assigned data fields and saved them but they don't "stick" just blank fields where I assigned parameters. I tried with the bike on and connected but either way the display settings are not saving.
Sorry if I answer only now... Could you post the configuration of the Display Customization?
Paolo, How do I know the version of my BLEvo? What is the latest version? Is there a charge for the updated version? Thanks!
BTW an awesome App.
Only downside is apple watch Heart Monitor integration but I understand the complexities of the IOS/Watch IOS and integration . . .
With iOS you can now the version of BLEvo when you start a new ride.
In any case you can go on Apple Store on you phone and check if there is the app to be updated..
@PaoloBLEvo have you had any thoughts on adding themes for Blevo? Or ui refresh? Or pluggable themes/skins?
This is not planned... I'm not a App developer and the user interface is very basic... Sorry for that..
I think this because you are using iOS version. The read mode of MasterMind TCU and Levociraptor Gen2 is for now available only in the Android version..
It will be available with the iOS app...
so meaning will not work with gen 3 at all ? pls advise. tks
Gen 3 works 100% with models that have the LED TCU. You get Smart Power control. With bikes that have Mastermind TCU you get all the logging features but no Smart Power control. This has been well covered only a few posts above.
I was able to source an LED TCU for my Expert and now have Smart Power Control as well as Levociraptor installed. Super easy to swap out the TCU. Looks like I can soon swap back I’m hoping.
would You sell your TCU2?
When Blevo becomes fully functional with the Mastermind TCU I plan to switch back. I would hang on to both TCU's just in case something changes in the future due to Specialized software updates.
After a year of riding my Gen 3 without Blevo, I finally broke down and replaced my TCU2 with the old version so I could use Blevo with this bike.
Is there a way to set the speed at 20MPH in the US? It automatically reverts back to 15.5 as soon as I try to raise it.
I'd also like to know this before I go and get a levocirapter
Hello,
is it also possible to use the BLEvo APP for other e-bikes that feature the Brose Mag S (e.g. the Bulls EVO 3)?
Best regards,
Thomas
Hello,
Best regards,
Thomas
No.. it is not possible.. sorry.. BLEvo is connected with the TCU, not the motor..
Has anyone succesfully paired Apple Watch Ultra with BLevo?
This is what i got when i first powered Levo and and opened BLevo. When riding at first heart rate stayed that same 64(not measuring anything?), then it became totally blank. So i finally put Strava on on my Ultra, seems to a better option. :D
What else i have to do than this?
hi need advise , each time thew apps when to sleep and when i want to resume the ride its kept showing this . in the end i have to start a new ride. i have already un check the hgt/dem amd did not able to restart too. pls help
WhatsApp Image 2023-03-20 at 16.43.50 (1).jpeg WhatsApp Image 2023-03-20 at 16.43.50.jpeg
Hallo, ich habe einen neuen 700Wh Akku erstanden.
Wieso zeigt er 720Wh im Batteriemonitor an ???
Ist das Normal? 20Watt extra wäre ja nicht schlecht...
Hi, can I destrict my speed limits using Blevo? My bike is Kenevo 2018 gen1 with 7.1.1 firmware аnd battery firm A.21.B ?
Pretty sure you need a Levociraptor or other hardware type device to enable derestriction. Once you have the Levociraptor then Blevo will set the level above 1:1 that you choose.
At least with older firmware versions, you could get a changed tire size from Blevo, which then affected the speed. I don't remember in that 7.xx version, but you'll find out if you try
    Join 43,125
