Other Turbo levo S Works Fatty 2018 One select button on remote stopped working
jonny strauss
9
Switzerland
Hi all. '+', turbo and assist buttons working on remote but '-' doesn't. The up / down on the battery works ok. So i have to use the '-' button on the battery then use the remote for '+'. Before i buy a new remote, is there anything to try? Is it worth opening up the remote to see if there's a loose connection or something? I'm no e-whizz. Thanks a lot.
pocii
20
11
would be water-damaged or the switch is broken. if you have no soldering skills or equipment....no chance
jonny strauss
9
Switzerland
Hiya, i can solder if a wire's come off but i wouldn't be so good at diagnosing the issue if i look in there and it's not immediately obvious. I was just wondering if someone else had button issues and generally it was x, y or z...common pattern if you like. But yes, if its water damage then it's a replacement...end of. Generally careful with water so maybe the wire was tugged too hard or something.
20,507
I think historically, when anyones had a problem they seem to have just changed the controller.
It could be the connection at the motor end, or the cable could have snagged or just broken over time. I guess you've nothing to lose if you take it apart and look.
outerlimits
E*POWAH BOSS
1,241
1,574
Most likely the remote water damaged. Pull the motor cover and check where it plugs into the motor first. It’s a small flat plug.
I could not get a 2018 remote as there were none available. Had to get a 2020+ remote and seperate patch lead.
The remote plug on this does not fit through the carbon frame, but believe it fits the alloy frame. I had to cut and splice the wires to fit. The patch lead box fits in the space above the battery.
jonny strauss
9
Switzerland
Thanks Outerlimits. I've got it booked in for replacement. I also couldn't get hold of the 2018 one. Was told also to use the 2020+ which i was going to do, then discovered the adapter costs more than the remote! So i gave up and booked it in, in the hope they'd have a stock version. Let's see if they do. But thx for your reply.
525K
