Lost screw
Tubby G
❤️‍🔥 Hot Stuff ❤️‍🔥
North Yorkshire
Now then …
Anyone know the size of this screw / bolt that managed to drop out of my partner's SLX shifter on the trail ?
i.e M6 15 ?
it’s the one with a red circle drawn around it
Tried a couple of bike shops, no success. They suggested I buy a new shifter, but reluctant to do that when all I need is a screw!
Sorry, I only came here because I thought it might be a bambam type screw thread ..
But seen as I'm here ..
Can't seem to find one for the i-spec ev .. presumably the internals are the same as the i-spec, which would be an M5
But obviously the actual screw shape is different on the EV.
I'm not sure if you bought the adapter if that comes with the correct screw ??
Whist you were both answering, I was just cutting down and fitting a bottle cage screw as I found a Reddit post asking the same question
The answer there was an M5 12 button head screw
Problem solved 👍🏻
My partner has a similar problem, but the screw isn't lost yet. It's just loose :oops:
    670K
