Loamranger
Thanks. Dissector for rear only then? What fast rolling tyre would match it on the front?Dissector is a very good rear tyre, but not in muddy conditions. It's also fast rolling and corner well
Maybe the NobbyNic for front.Thanks. Dissector for rear only then? What fast rolling tyre would match it on the front?
Anyone with experience with Dissector front and rear? For second wheelset to experience different tyres.
Yes, I'm running the Dissector both front and rear on my Ibis Mojo HD3.
Previously on that bike I was running DHF's, and before that Nobby Nic's.
I just started using 2 DHF and the Nobby Nics might be next if i can find some.Yes, I'm running the Dissector both front and rear on my Ibis Mojo HD3.
Thoughts? Do they roll better than the others?
Continental Xynotal Trail Endurance are the faster rolling hardpack tyres in the new Continental range. Anyone tried?
What compound/sidewalls are you thinking of using? What is the Dissector/DHR2 compound/sidewalls?I also fancy trying out the Kryptonal / Xynotal combo for my next set of rubber so interested to hear some feedback
In 2.4 or 2.6 front?Probably the soft enduro Kryptonal up front for grip, and the trail enduro Xytonal on the rear for faster rolling
Not sure what sizes the Conti’s come in but I prefer 2.4 front. 2.3 rear
I’ve never tried double DHF but DHF front and DHR2 rear would roll better, I’ve used that classic combo and it’s hard to beat as an all round set up. Perhaps consider DHF front and Dissector rear, that’s definitely more roll.I just started using 2 DHF and the Nobby Nics might be next if i can find some.
Mainly i do XC and trails. Should i stick to DHF?
What compound/sidewalls are yours?
Yes, rear only and MaxTerra compound, Exo+ 2.4 WT. I have Specialized Butcher 2.3 T9 front and Maxxis DHF MaxTerra or MaxGrip is also very good.Thanks. Dissector for rear only then? What fast rolling tyre would match it on the front?
Sounds like a good plan. Is Kryptotal like Assegai and Xynotal like Dissector or Rekon perhaps?Probably the soft enduro Kryptonal up front for grip, and the trail enduro Xytonal on the rear for faster rolling
Although designed for similar use and conditions the Kryptotal's tread design is nothing like an Assegai's. And neither is the Xynotal's similar to a Dissector or Rekon
If you want a tyre that handles like an Assegai upfront and a dissector rear. Buy those actual tyres.
I'd struggle to comprehend why anyone would even consider using a tyre like a Rekon in conjunction with an Assegai. And I absolutely love a semi slick rear paired with a DHF or DHRII upfront
Yeh, not much out there in the way of reviews atm to help decide.I guess so. The Kryptonal also comes in front & rear options, so could just use those with a soft compound up front and trail / enduro on the rear
No idea on compound, just thought I would give it a tryDo you happen to know is that soft compound near to compound that Barons use?
Maybe i could try Kryptotal to front.
