is that clearance measured in UK or US units?
How's the flip-chip? Low or High?To answer the questions, yes you can put 29 wheels in the rear without issue
Untitled by Sales Punk, on Flickr
To balance out the bike the fork is a 29/170 setup
To answer the next question, the BB height is not a hinderance at all. Mine measures out at 361 or about 7 mm higher than my Enduro. The bike is insanely fast every where. We ride a lot of very steep and raw natural trails along with some big jump lines and the bike absolutely slays. Getting to those trails is done via steep technical singletrack climbs with lots of tight switchbacks. Again, no issues with the 29 wheels. Happy to answer any specific questions about the changes.
Untitled by Sales Punk, on Flickr@SalespunkMy LBS is getting some Kenevos in next 2 months and thinking about making it a full 29er just because it’s one of the only Ebikes that can fit me. How did the geo change such and reach and stack change do you know?
Original Marzocchi Bomber Z1 180 27,5 has Axle to crown 562Reach and stack will remain the same, bottom bracket and stand over height will increase a bit.
Fox 36 29" 170 has axle to crown 577
29" wheel and 2.4-2.5 tire brings the height more by about 16-20 (correct, if it's wrong)
Totals about 30-35 mm
That's why I changed the fork to 170 and removed one spacer under the stemYou”re correct sir, I forgot the fork will be replaced. Reach will be a bit shorter and stack higher.
ThanksRydeezie, nice looking rig. What size is it and do you have the weight, please?
What travel 38's are you running? And hows it compare to the 40's?29er conversion on the kenevo, and switched my 40’s out for 38’s View attachment 85595
Hi Rob, I’m running 170mm. It’s more agile on ascents with tight switch backs now the forks aren’t hitting the frame. They really shine in tight technical trails, but no noticeable difference on smooth flowing trails. Small bump sensitivity has improved making the tracks I mainly ride feel smoother, this could be a combination of bigger wheels and more flex in the fork.What travel 38's are you running? And hows it compare to the 40's?
Thanks mate, helps a lot.Hi Rob, I’m running 170mm. It’s more agile on ascents with tight switch backs now the forks aren’t hitting the frame. They really shine in tight technical trails, but no noticeable difference on smooth flowing trails. Small bump sensitivity has improved making the tracks I mainly ride feel smoother, this could be a combination of bigger wheels and more flex in the fork.
On the flip side, big high speed breaking bumps are harsher under heavy breaking, I think this is because it’s higher up in the stroke, so in a stepper part of the progressive spring rate curve if that makes sense? I’m thinking about trying a secus to see if that’ll help since they’re meant to make things more linear, but that’s probably only 5-10% of the tracks I ride.
Overall a better riding experience. You won’t find me putting 40’s back on my bike anytime soon unless I plan on doing red bull rampage, which is never happening![]()
No problems with a 29/2.5 maxxis. I used to run 2.6 butchers without an issue. Might be a problem in muddy condition’s picking up sticks and stones though as the clearance is close. I ran it also with a Sicomtb guard and it had around 5 to 10mm clearance. In the end I chose to run 2.3 tires as they were more than enough for what I needed.Hey guys, I am running my S3 Kenevo in Mullet (180mm f/r) now. IMO much better than stock. But I am considering now going 29 f/r as it might turn better (steeper HA).
Does a 29er fit in the rear of an S3 with a 2,5 Maxxis tire? I read somewhere that a 29er in the rear might have clearance issues with the saddle "on smaller sizes".
BTW EXT e-storia works like a charm - strongly recommend it. ;-)
I have had the EXT e-storia for a few months on my kenevo and all I can say is Amazing! Kinda ruined me riding stock suspension probably forever at this point.Hey guys, I am running my S3 Kenevo in Mullet (180mm f/r) now. IMO much better than stock. But I am considering now going 29 f/r as it might turn better (steeper HA).
On your Storia are you running the 62.5 mm stroke or 65 mm? I have a Storia in 62.5 mm that I'm wanting to try on my Kenevo.Hey guys, I am running my S3 Kenevo in Mullet (180mm f/r) now. IMO much better than stock. But I am considering now going 29 f/r as it might turn better (steeper HA).
Also what is your flip chip position?
Thanks,
Hello. Anybody having had issues with the EXT shock in the Kenevo? Does the manufacturer clesr the shock for Kenevo? Afraid for potential warranty issues.I am running the 62.5mm. With the Mullet setup I preferred the high position. With the 29er f/r I was testing a lot with different setups but ended up with the low position as overall the best configuration for me.
In my country (Austria) the official EXT distributor/dealer has installed it on several Kenevos and Levos. So should be fine but I recommend talking to the distributor/dealer in your country.Hello. Anybody having had issues with the EXT shock in the Kenevo? Does the manufacturer clesr the shock for Kenevo? Afraid for potential warranty issues.
Cheers
Andre
I feel my27.5 kenevo hooks up badly on bumps (roots) with an ohlins ttx22. Great on single big hits but terrible on repeated hits.Hello everyone. Has anyone found the rear-end feeling like it hooks up on medium to high speed small bumps after converting to a 29er? It's a sensation that's like the high-speed compression is dialled right up, and that first quick hit is really stiff and then settles after the first bump once its further through the stroke. It's almost like someone momently grabs the back wheel so you feel like it could potentially send you over the bars.
I've done zero justice explaining it, fingers crossed someone understands me
