Bafang M600 Spider
Dave Rand
111
145
Kent Uk
Evening chaps,
If there a non dished Spider I can get for the M600?
My Chain line is a bit crap and I would rather not use chain ring spacers to move it over 😐 as I need at least 5mm
Dave Rand
111
145
Kent Uk
Definitely needs to be 5-7mm over.
Think I’ve found one and ordered it but apparently China in lockdown 🤦🏻‍♂️🤦🏻‍♂️🤦🏻‍♂️
patdam
808
552
france
Are you sure you will not have a problem between chain and lower swing arm pivot if you perform your modification ? it's depend of Nb of teeth of your plate, but chain pass allready very close with OEM spider. i have installed protection and it is damaged.
Dave Rand
111
145
Kent Uk
It’s miles away from the swing arm.
I recon the 52cl Bafang spider is designed for proper 148mm boost hubs. Mine are old school Hope pro 2 hubs with 148 boost adapters which means my Cassette sits further in the wheel.
patdam
808
552
france
OK, if you don't find it is not so difficult to change the hub (lot off time but not complicate)
525K
