Reign E+ 2022
A bit of topic but I just saw this. Maybe something for @Rob Rides EMTB and you guys with long legs.
As it turns out I just ordered a bikeyoke max revive 213mm But had the 210 dropper from OneUp on another bike and it was really decent, great value for money. I didn’t have any issues with it in 12 months.
Yah they are great! Best thing is the option to shim it down. You will always get the longest possible dropper!
Starting to get pricy. last year I paid 230 euro and now 260 euro for the exact same model.
Well, It’s vertical wheel travel I measured. So technically is a measurement of rear wheel travel 🙂
I agree, it’s not the exact measurement that manufacturers use (although their quoted travel number is likely not the exact figure either, it’s too rounded and nicely marketable a number to be always ending in a zero!)
I totally get that it’s not following the exact arc that the rear wheel travels. I wonder how much of a difference in reality this number will be, versus the variation of measuring the exact axle path. Obviously will differ from bike to bike depending on a few things.
My measurement works out Axle Displacement, not Axle Path Length 👍 for sure there will be a difference, but I’m not convinced that it’ll be more than small single digit % variations?
No Rob.
Believe it or not most bikes do actually have very close to the actual quoted travel. Designers don't just guess linkages and shock eye to eye lengths.
Your (wrong) measurement can easily be anywhere between 4-10mm out. (depending on traval and true axle curvature).
At an "educated" guess I'd say you're right around 6mm out this time 😉.
PS. Fork travel would be shorter too if measured your way.
So, pick my reign up Thursday. Going the orange spec as everything on it is coming off. Already have tricksruff brakes, super deluxe ultimate and a coil conversion for the forks. My question is for putting it in the roof, the battery will come out and front wheel off as it's an angle mounted carrier. With the battery out is there a cover for this or do I need to wrap the frame to protect from the elements?
Battery cover and battery are independent. You will be able to close the frame.
I think so too, or they use another mapping!
Were you guys really able to climb anything harder with different motor? I absolutely crushed all the uphills on Reign that I was able to do with Bosch motor. Bikes when it comes to geometry were similar. Bosch is more punchy and surges much more, but most definitely not more capable. Of course it's just my single opinion.
Exactly. My pal has the Bosch and couldnt do a hill challenge. Mine just shot up its all because the yamaha is very smooth power compared to Bosch
EWS Climbing stages are perfectly do able on a normal bike. But being a timed segment every second counts.
Most climbs folk do on Ebikes are do able by stronger fitter more skilled rides on normal bikes TBF.
Quick tip for people riding the Reign E+ 0 & E+ 2 with Sram Code brakes.
Bikes are specced OE with Sram Centerline 220mm/200mm rotors, front one being 2.0mm thick & rear 1.7mm.
I was finding my lever throw a little bit off for the rear brake as the rotor is not as thick as the front one.
Upgrading to Sram HS2 rotors which are 2mm thick for all sizes was a nice little upgrade with better brake feel especially regarding the lever throw. Rotors also have a larger braking surface vs. Centerline...should improve performance a bit.
E+ 3 spec comes with 203mm rotors. Domain fork is 200mm standard. Is the frame be default 200mm? Presume they have added a spacer for the 3mm
Yamaha is fine but in a race seconds are important and here it is not the best in my opinion.
the new santa cruz heckler released today and already 12 reviews from the ''famous'' youtubers, reign e+ released 3 months before and is like don't exist . what going wrong ?
Always the way with giant for some reason.. think they do need to improve there marketing. I see they have gone abit into town with embn this year tho
Yah it’s like the marketing department dropped the ball. Might sort it self out soon. Giant launch was far ahead of wide availability. Might be a wave of review arriving this spring. Most ppl buy in march/April/may.
Yeah. The largest manufacturer of bicycles in the world should definitely come to a forum full of old blokes for advice on how to sell more bikes.
:rolleyes:
Yep! New Heckler, very nice bike, good specs, geometry similar to Reign E+, lighter, Shimano EP8, clackity clak, and of course 🤑 pricey.
Good luck trying to get one 😬
It absolutely doesn't matter what's going on. Your new Santa Cruz WILL be made in the same Giant factory. As most bicycles. Something like competition doesn't exist for Giant cause whatever is sold is nevertheless made by them. They always win. Santa Cruz like lots of other companies produce absolutely nill. They just check if what came back from Taiwan to US looks good. They don't even run serious tests. They showed ones how those tests look like. Some bloke was jumping on the rear triangle. Best quality control ever :/.
  • Like
Reactions: MO1
The biggest difference for me between the Bosch and the Yam is on super rocky, narrow climbs that you dont know too well. When you cant even get a 1/4 pedal stroke in and your almost done the Bosch lets you do a super quick jab on the pedal and that little boost that it gives almost always gets me through. The Yam doesnt give that. I do feel like the Giant has really poor engagement on the rear hub and that doesnt help the Giant in that situation either. Small differences and first world problems.
I had a small frame E+1 on order here in NZ (all that is coming in), figured I could make it work as I have had other small Giants in the past (anthems and Trance) and reach was just 5mm shorter than my levo on paper. Was lucky enough to take a med E+1 for a good ride and realised I could not go any smaller, maybe it was the seat tube angle which made me feel a bit cramped? I was also concerned about battery consumption (no sign of when range extenders will arrive in NZ, if at all) and frankly not overly impressed with the motor. I did like how it turned and the spec is awesome for the $$. I am coming off a 2019 Levo with good Fox gear on it and 700wh battery (which I could do 80km on if needed), a bike I raced E-Cross Country and E-Enduro on and performed well, just sold it for more than I paid for it 3.5 years later. Now decided to stick with another levo, due to the improvements over the old model, adjust geo, mullet, 700wh etc, so have a levo comp alloy on order. A couple of grand more but all I could think of was how good the levo was when I was riding the Giant and the resale in a couple or 3 years time will cancel out the extra $$. Just my opinion but I see alot of readers like to read comparisons.
:rolleyes:
Yeah because they are really struggling to move stock at the moment. The bike shops are running out of floor space
    Join 43,262
