• Warning!!
    UK Pedelec Law
    Worldwide Laws
STUnlocker (ex Shimano STEPS Unlocker) Android & Windows App for derestriction/market change and etc
KuRi
376
186
Spain
I have just tried but it gets stuck on 0% when trying to update:
KuRi
376
186
Spain
I tried several times... even after restarting...
Can you upload an iOS version as well? I bought both some time ago :D
vadII
768
567
Earth
It's uploaded for iOS, but it takes 1-2 days to approve the new version by Apple...
p.s. The new version (.108) was uploaded to Google Play also, may be it will work for you...
Mart-e
69
40
Recently had a wheel true - spoke tension - replaced cassette..... the WO11 appears?
Not realising the magnetic was offset l then turn on STU app for clues.... tapped on Circumference..... changing the selection then back to Custom.
As a result later reading on possible causes the misaligned magnet was to the cause WO11....
I realigned magnet.... All powered up which is pleasing... only now restricted back to the limit?
Would appreciate input, a way to be reconfigured please.
Thank you.
Thanks!
vadII
768
567
Earth
You have a physical/electrical problem with the speed sensor. It has nothing to do with the settings of your bike.
Mart-e
69
40
Thank you vadll validating a electrical problem a result of the speed sensor...... I will research for the replacement speed sensor to the reinstall.
Thanks again.
aarfeldt
711
631
Denmark, Danstrup
Thank you.
Thanks! View attachment 78188
What app is this ?
Mart-e
69
40
Thank you vadll, l thought to run over this situation once more before upgrading parts another sensor.
Set up bike on the stand repositioned the magnet.... Took it for a run and fortunately NO error code is displaying..... the motor engages throughout the chosen settings Eco - boost.... only restricting the factory settings country of origin.... checked again on the app "Circumference" displaying "700c." I thought it possible "Custom" be chosen?
Just working on establishing wether the speed sensor still shows to be at fault as the error code no longer appears.
Thank you vadll.
Sgur
10
Italy
Mmm, I just tested this on emax on my orbea rise and they were changed, and it did make a difference. After changing these params the new values appeared also on the stunlocker app (250,350,500W).
However when setting to 500W and 85nm the motor were doing some bad vibrations when battery < 30%.
I don't know how they did it but I know you are a very experienced developer with shimano motors so I trust your opinion a lot... Let me know if you need some screenshots. Thanks!
Hi KuRi I read you reported some bad vibrations after having modified original Rise power parameters. Can you tell me more about, problem still present? Do you think it’s to do with too much power allowed?
thank you
KuRi
376
186
Spain
Hi! Yes, after some more testing, it is all battery related. There is too much drain from the motor when >350W. That's why Orbea limited boost setting to 350W.
When the battery is full, you can use 400W-450W without problems, but as you reach 50% or less you start noticing some vibrations.
I have set up the boost setting to 400W and can be used for the whole range of battery with only some slight vibrations when <20% battery.
Hope this helps!
Sgur
10
Italy
Hope this helps!
thank you
Indeed it does! I‘m not going to increase max power this being the case…😱😳
gigabyte772
10
So I just got an Orbea Rise H10 but i upgraded fw to latest 4.1.8 by accident. I have copied the 2 files to the android fw folder, I tried to remove all files and just keep these 2 files and also just copied them with all other files, but it will not give me option to downgrade the software FW, it just stays on update page with no option to downgrade. Suggestions?
Nebo1ss
47
17
London
The downgrade firmware normally have a file name larger than existing firmware. It is typically 5.0.2 on the file name but is actually 4.0.2 firmware and hence the system things it is upgrading not downgrading. You should typically delete all the files from the FW folder and replace only with the 2 files that you need to downgrade.
gigabyte772
10
I tried that. It is not prompting to update firmware.
Nebo1ss
47
17
London
Did you update the ETUBE application to version 5.0.3. `There is a comment in the update that says "Improved the modification detection function for unauthorised tuning" I wondered when i saw that how they could do it in ETUBE instead of the motor firmware but it is possible they are now preventing downgrades of the firmware somehow.
This is only a guess.
KuRi
376
186
Spain
I am not sure about downgrading but that could mean that it will detect if the motor output (in W) or torque has not the default values also...
Edited: Yes, it has been confirmed that you cannot downgrade (yet) with the latest e-tube app. You have to install an old version.
gigabyte772
10
Where can I get older version?
KuRi
376
186
Spain
No you dont need additional files there. I have only those two and it is working. Just be sure you have etube 5.0.2 or older.
however mine were 5.0.0 and 5.0.2 not 9.x.x
529K
