Reign E+ 2022
G'day all. Thanks for all the info shared on this thread, it's been great to read.
Short story long, I picked up my Large Reign E+ 1 yesterday. I'd never ridden an emtb before so I wasn't sure what to expect. The brakes need to bed in, so I rode an easier trail, XC but with some decent chunk rock.
A few thoughts from my first ride.
* Heavy to bunny hop and pop, UNTIL I started using the motor to help, when I gave a pedal stroke to initiate the hop/pop it propelled it forward and up - it felt much like back wheel hopping in trials. Need to play with this now, but I think it will be great fun. Same for power wheelies out of corners, learning to use the motor seems key. Lots to learn.
* Climbing - nuts. Tech climbing was too much fun, it carried speed up rocks that normally require careful entry speed, weighting, and power application to get up. The Reign E+ was getting me up techy sections so much faster and easier. I can see it will change what I will want to ride, tech climbing will be awesome. I was actually breathing harder than normal because it gives you incentive to hit stuff faster (and spin more). Road and fire-road climbs were just awesome. The motor was much happier when my cadence was up, so I am re-learning to spin.
* Singletrack with mild techy bits - I kept arriving at the usual slower flat and uphill corners MUCH faster than normal, which totally changed the feel of the trail. It was much more intense than usual, and huge amounts of fun, flat and mild uphill became more like dh - drifties everywhere. Surprisingly, it steered better than my normal (160r/180f 650b) bike, and I didn't notice the weight being an issue even at slower speeds on tighter sections of track. That said, if they build a sub 20kg version one day, of course it will be more agile, but this bike is agile - I was worried when I first picked it up that it would be a ship and not change direction, but once I was pedalling it was great.
* Drops - rode one 6ftish drop, was stable and smooth.
* 29er front - amazing, the wagon wheel just smoothed out the trail, and made steep tech rock roll downs much much easier than on my normal mtb.
* Only one jump, a faster gap, not steep, the bike was noticeably heavier than usual, but was far more stable than my normal mtb, and cleared the gap fine.
That's all I can think of for now, hoping to bed the brakes in properly and then get it on some steeper, faster local trails next week to test it properly.
Any questions please ask.
Cheers 👍🍻
@Tim gosnold - regarding your question on Insta about the range of the 750wh battery: I haven't managed to run it until it was fully empty. After 1400m of climbing in Smart Assist mode on steep trails I still had 25% left. If I extrapolate this to a 100% it would give me ~1850m of ascend, which sounds resonable because I can get 1600m out of the 625Wh battery when using Eco/Basic mode.
With my 500Wh spare battery I`m getting the same range as with the Trance X / SX e+ (1100-1400m, depending on temperature, rider input, assist mode etc.).
Is the energy pak range extender compatible with the 2022 model?
Thanks for getting back to me on that, and what sort of distance did you manage to cover. That’s interesting to know the range extender pack will fit the bike also. 👍
hi to all,i just order a giant reign-e2 2022 in medium size , has anyone know the length of the stem because on giant site say 40mm on medium and many medium bikes cames with 50mm.also giant rear hub is good or not,any experience?
The Giant e-Tracker hub on the E+ 2 is an OEM made by Formula. I did brake two of them 🙈 with 11-speed on the Trance SX e+ in the highest gear because of too much torque. Shouldn't happen so easy on 12-speed anymore. E+ 1 doesd have OEM DT-Swiss
Stem lenght varies based on availabilty. My medium did come with 40mm stem, but I changed to 50mm straight away to adjust to my sweet spot in terms of reach.
Cheers 👍🍻
Which water bottle is that, any recommendations? Want to get the maximum size bottle in the frame, looks like though I'll need to go back to carrying a backpack/hip pack etc...for additional water... :( I guess you can't have it all....
It's just a Giant bottle, 500ml I think, the bike shop wacked it on for me. My frame a large, a 750ml will not fit, it's a tad annoying for summer because it gets pretty warm here and you lose a lot of fluid, but I'll just use a camelbak, no worries at all.
How's the battery life on these. Not sure I'll be able to get one anyway as contacting giant stores they are only getting one or two in.
Bike24 has the E+ 3 in stock. Some other german online store had e+1 (but not medium). So you can find it online.
My E1 is now confirmed. Delivery w5-6. It’s completely fine as usually have snow until w8-10.
Mine arrives in AU mid December...only a few around I believe..you might get lucky doing a ring around....
I’ve got one on order and deposit payed.
They are giving them out in order of payment made!
I did initially ring around and if your out of area they won’t let em go either!
Crazy times
Just gotta wait
@Rob Rides EMTB - there are some reports the battery would drain quicker than expected.
Other riders claim the PW-X3 is not as powerfull as the PW-X2, cannot compete with Bosch Gen 4 or E8000/EP8.
I cannot agree on any of these statements as my Reign e+ 1 2020 just works flawlessly.
But maybe you can have an eye on that while you do your testing.
Last week I scouted a tour with the Syncdrive Pro (PW-X2), and this weekend I repeated the loop with the Syncdrive Pro2 (PW-X3).
400m ascend on trail, steeply uphill, partly wet and muddy, high steps and blocked places, also had to stop every now and then and start again which all costs battery. Downhill some short, steep counter climbs. The conditions were like to like, therefore a valid comparison. But since the fun was in the foreground this time, I rode everything with level 4/5 or in Smart Assist mode. BTW: no problem to keep up with the EP8 ;-)
Temperature 5-10 degrees. A total of 900hm on 90% trail. Mainly level 4/5, otherwise automatic. At the end 39% battery remaining . The EP8 with 540Wh battery had only a single bar left, although the driver is clearly fitter and lighter. This showed once again how much the temperature, surface, difficulty and the riders ability to tackle demanding terrain has an influence on the battery range.
Personally I find the Giant Syncdrive Pro2 feels even more natural than its predecessor. No longer that nervous when you tip on the pedal, and the more input I provide, the more support I'm getting. Less spin-outs than before. Therefore, more predictable in the terrain. I've also pulled many power wheelies while riding with a high cadence, which is not quite so easy with the PW-X2. If someone really will notice the additional 5NM of torque in reality? I don't think so. And I don't mind as I always had and have enough support.
RRP on the Trance +0 is apparently £7999 which is unbelievable value in current marketplace, though I have to say live valve has no interest to me.
I'm with you on the Live Valve, but as it is included in the Trance Advanced E+ 1 I've ordered there is no way arround it. But my wife will love it - no more knobs to twist and wonder what the heck they are ment to be for :giggle:
Happy to see the weight savings (22,2kg in Size M according to this review) and that it's going to remain a versatile allrounder.
    Join 43,198
