It will go a lot further if you stick to the lower power modes, I think if I did a ride in mode 2 or 3 the whole time I could go quite a bit further. While I’m climbing in auto it definitely is using full power while going up fire roads, if I use auto it will use a bar of battery in the first 20 min or about 7 or so km of riding. I’m also 230lbs, so that probably doesn’t help.
I get the stop pedalling noise out of the motor as well, the noise I heard was while pedalling up using power, I’ll see if it happens again.
