Legendary-dave
153
65
So I want to take the drive side cranks and motor housing off my turbo levo and give the motor a clean and check leads are not got any water ingress in them , I’ve watched a video on the procedure and am purchasing a bbt8 castle nut remover , I also need a 2 legged puller to remove the chain ring , can anybody tell me what size puller to purchase, I don’t want to buy something to big or small for the job , thanks
6,200
4,706
75mm or 100mm will do it.................but you do not gain much by removing the motor. Once the battery with bash guard is removed and the non drive side motor cover is removed, you have access to virtually everything you need to clean and check the wiring.
Legendary-dave
153
65
Thanks 🙏……
Swissrider
364
381
Switzerland
Be careful what you screw your puller on to. If you screw on to the spindle you can push it too hard and break the inside of the motor. You need a spindle (or socket) which fits around the spindle and push against that.
Legendary-dave
153
65
Thanks I’ve seen a socket used for that , 25 mm I think was mentioned
528K
