Levo Gen 3 2022 Levo Gen 3 - Schematic for SMALL PARTS
Kiwi in Wales
Short cranks rule!🏴󠁧󠁢󠁷󠁬󠁳󠁿
Carmarthen, Wales
Download PDF
This is really cool. Anyone have a source for a 2020 version?
Yes, but the schematic for the SMALL PARTS was to big to post on here.
Here is the schematic for the CABLES.
@Rob Rides EMTB said he could host the schematic for the SMALL PARTS on the Forum server but not sure if he has had time to do this yet.
KIWI, AMAZING !! This stood my hair up on end like sliding on pea gravel toward a desert ravine !! But in a REALLY good way. I have been searching for this. With the cost of these bikes, the technical data is tough to find!! THANK YOU !!
I noticed the posted Technical Guide above has torque specs on page 35 that are flip flopped vs what is in the actual hard copy manual that comes with Gen3 Levo. Was checking the forward and rear shock bolt torque's and the above posted tech guide has 90Nm for the front and 185Nm for the rear...the hard copy manual says 10Nm for the front and 21Nm for the rear. Went with the hard copy torque specs.
If anyone is looking for the seatstay rear brake hose clamp pictured on the Full Cable Routing Guide, the part number is S206500009.
Is there something similar for the Kenevo?
Some parts seem to be the same, but others not. And I couldn't find anything on the Specialized page.
Hi,
does anyone know if this kit is also compatible with the 2025 Turbo LEVO Gen3?
I want to completely close the right side of the frame.
And please excuse my limited English skills🙄
Thanks in advance
Klaus
Hi,
Thanks in advance
Klaus
Hi,
I'll answer my question myself.
The kit is also compatible with the 2025 Turbo Levo Gen 3.
