Kenevo Gen1 2022 Kenevo comp & expert
#mitch
🦷 Tooth Fairy 🦷
New Zealand
Hey all after a year of waiting I think my Kenevo will arrive in November. Wondering if anyone has any info about the 2022 models. My shop said the frame is the same as well as the motor but the shock is the air one and it’s got a 12 speed now.
So I have been digging and this looks like its the new bike. Specialized Kenevo Comp SATIN FOREST GREEN / PINE GREEN S5 - Alpha Bikes From what I heard it looks about right. Gears look like a 12 speed and has the air shock (but so do the newer pics of the 21).
It would be a disappointment if the comp models didnt get updated to come with a 38 or zeb.
What is this, I thought people were saying we were getting a full redesign on the Kenevo? Very lame
Yeah for over £5k I’d expect a better fork than the Z1, at least the base 38 fox/rs !
With normal Specialized product cycle (3 years), new FF Kenevo will be MY2023.
And Z1 is a great fork.
Yep, that color looks great... yet another price increase from 6099 Euro to 6600 Euros:rolleyes: for the comp...
Given the ongoing shortage of almost all components and the cost of shipping like 4-6x what it was at the start of 2020 I’m not surprised.
and the Experts:
SATIN DOPPIO / SAND:
Rahmen:Specialized M5 Premium Aluminum, 27.5 Trail Geometry, integrated down tube battery, enclosed internal cable, Command Post routing, 148mm spacing, fully sealed cartridge bearings, 180mm of travel
Gabel:RockShox Boxxer Select RC, 27.5, DebonAir, 20x110mm Boost™, 35mm chassis, 180mm of travel
Dämpfer:RockShox Super Deluxe Select Plus, 230 x 62.5mm
Motor:Specialized Turbo Full Power System 2.2 Motor
Akku:Specialized M2-700, integrated battery w/rock guard, 700Wh
Display:Specialized MasterMind TCU, percentage of remaining charge, 120 possible display configurations, MicroTune assist adjustment, over-the-air updates, ANT+/Bluetooth®, w/Handlebar remote
Ladegerät:Custom charger, 42V4A w/ Rosenberger plug
Schaltwerk:Sram X01 Eagle, 12-speed
Schalthebel:SRAM XO1 Eagle trigger, 12-speed, single click
Kettenradgarnitur:Praxis Carbon M30, custom offset, 160mm
Kassette:SRAM XG-1275, 12-speed, 10-52t
Kette:SRAM GX Eagle, 12-speed
Lenker:Specialized Trail, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 30mm rise, 800mm, 35mm clamp
Griffe:Deity, Knuckleduster, Black
Vorbau:Descendant 35mm Direct Mount Stem, 50mm length
Sattel:Bridge, 155/143mm, Hollow Ti-rails
Sattelstütze:OneUp, Dropper Post-V2, MMX lever, 34.9 (S1:120mm, S2/S3:150mm, S4: 180mm, S5/S6: 210mm)
Sattelstützklemme:Alloy, 38.6mm
Bremse:SRAM Code RS, 4-piston caliper, hydraulic disc, 220mm
Vorderradnabe:Alloy, sealed cartridge bearings, 20x110mm, 28h
Hinterradnabe:DT Swiss 370, 6-bolt, 12x148mm thru-axle, 32h
Reifen:Butcher Grid Gravity 2Bliss Ready T9, 27.5 x 2.6"
Schläuche:Presta, 40mm valve
Felgen:Roval 27.5" Alloy DH, 28mm internal width, 32h, tubeless ready
Speichen:DT Swiss Industry
Pedale:nicht im Lieferumfang enthalten, passende Pedale finden Sie in unserem Zubehör Programm!
Gewicht:ca. 30.11kg
Given the bike looks mostly the same that shouldn’t be different than the 21? Do you know the weight of that?
No I don’t have the weight of that. But the build looks similar. Extra weight maybe from the Grid Gravity tyres (about 1.35kg each), one up V2 dropper, 12 speed gears, 220mm rotors.
That’s got to be a typo though otherwise it’s the first eMTB that’s tipped 30kg.
30.11kg is propably a typo!
The Expert gets the Mastermind TCU, while the comp models getting the old TCU...that aint cool(n)
The Comp Specs:
Gabel:2021, Bomber Z1, 27.5in, Marzocchi, 180, Grip, Sweep-Adj, Matte Blk, Neutral/Matte Blk Logo, Kabolt 110, BLK, 1.5 T, 44mm Rake, N/M OE.
Dämpfer:Fox Float X Performance Series, 230x62.5mm
Akku:Specialized M2-500, integrated battery w/rock guard, 500Wh
Display:Specialized TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, w/Handlebar remote
Schaltwerk:SRAM GX Eagle, 12-speed
Schalthebel:SRAM GX Eagle, trigger, 12-speed, single click
Kettenradgarnitur:Praxis forged M30, custom offset, 160mm
Kassette:SRAM NX Eagle PG-1230, 12-speed, 11-50t
Kette:SRAM X-Sync Eagle, 104BCD, 32T, steel
Lenker:Specialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm width
Griffe:Specialized Trail Grips
Vorbau:Alloy Trail Stem, 35mm bar bore
Sattel:Bridge Comp, Hollow Cr-mo rails, 155/143mm
Sattelstütze:X-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SRL LE lever, 34.9mm, S: 125mm, M/L: 150mm, XL: 170mm
Bremse vorn:SRAM Code R, 4-piston caliper, hydraulic disc, 220mm
Bremse hinten:SRAM Code R, 4-piston caliper, hydraulic disc, 200mm
Vorderradnabe:Alloy, sealed cartridge bearings, 15x110mm thru-axle, 28h
Hinterradnabe:Alloy, sealed cartridge bearings, 12x148mm thru-axle, 32h
Gewicht:ca. 30.02kg
No the Z1 is a basic but good fork and not one that should come on a £5800 bike !
Fox/rs 38’s are great forks !
any m
Its just a filler...they are just kidding around...
As in messing around regarding the weight or the bike itself?
can’t find anymore info on the web ?
do you think we’ll see these in the UK this year?
There are so interesting bikes hitting the market now that rival the Kenevo IMO. This new Haibike looks interesting (well Haibike and looks are pretty subjective :cool: ) and at 6.5k with 750wh battery and the Ohlins bling bit of a deal
Theres also the Husky, though not a bike that appeals to me
any m
No idea about the UK but I have one on order that’s supposed to be delivered in November to New Zealand. With the way shipping is going I won’t be shocked if that’s delayed.
Maybe I’m not enough of an ebike convert yet but both of these look way too thic for my taste which is why I’m going for the Kenevo. Positive others will enjoy them though!
No new info but listings have started popping up in my country. Specialized 2022 Kenevo Comp | Cycleways
Comp Specs:
Frame: Specialized M5 Premium Aluminum, 27.5 Trail Geometry, integrated down tube battery, enclosed internal cable, Command Post routing, 148mm spacing, fully sealed cartridge bearings, 180mm of travel
Rear Shock: Fox Float X Performance Series, 230×62.5mm
Fork: 2021, Bomber Z1, 27.5in, Marzocchi, 180, Grip, Sweep-Adj, Matte Blk, Neutral/Matte Blk Logo, Kabolt 110, BLK, 1.5 T, 44mm Rake, N/M OE.
Front Brake: SRAM Code R, 4-piston caliper, hydraulic disc, 220mm
Rear Brake: SRAM Code R, 4-piston caliper, hydraulic disc, 200mm
Rear Derailleur: SRAM GX Eagle, 12-speed
Shift Levers: SRAM GX Eagle, trigger, 12-speed, single click
Cassette: SRAM NX Eagle PG-1230, 12-speed, 11-50t
Chain: SRAM NX Eagle, 12-speed
Crankset: Praxis forged M30, custom offset, 160mm
Chainrings: SRAM X-Sync Eagle, 104BCD, 32T, steel
Front Hub: Alloy, sealed cartridge bearings, 15x110mm thru-axle, 28h
Front Tire: Butcher Grid Gravity 2Bliss Ready T9, 27.5 x 2.6″
Rear Tire: Butcher Grid Gravity 2Bliss Ready T9, 27.5 x 2.6″
SeatPost: X-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SRL LE lever, 34.9mm, S: 125mm, M/L: 150mm, XL: 170mm
Motor: Specialized Turbo Full Power System 2.2 Motor
Battery: Specialized M2-500, integrated battery w/rock guard, 500Wh
I wonder why they went with mullet for the Levo but not the Kenevo? maybe waiting for the next Gen?
    Join 43,210
