Reign E+ 2022
No need to dress up in your sexy clothing .. ;)
Lets see what you come up with ..
Dressing up is the fun part! Measuring the angle from an image is boring, and probably pointless (: Anyway,11,74* it says... So about 78* (90-11,74)
Dressing up is the fun part! Measuring the angle from an image is boring, and probably pointless :) Anyway,11,74* it says... So about 78* (90-11,74)
Thank god you didn't suffer some static shock catastrophe !
I've just re-measured your image and get the same, well 11.7. Does this mean my paper mache model is not accurate ? Or your image is not a true representation of reality ?
If I measure @hexagon's images :
I get the same 80 degree (10) on the new one and 12.4 from crank centre to post top on the old one.
I'll go 25.0257 kg for he E+0 ... in Medium - Tubeless.
I ordered exactly this, E+0 size M and I think 25kg with 750 battery
I really hope that @Rob Rides EMTB tells us everything, absolutely everything about this bike, and above all I am curious to have information about this new engine, and to know how the automatic mode behaves.
Also I'm curious to know if this geometry with vertical seat tube really helps uphill, because I hope so !!
I did almost goto the Giant shop but it closes at 7 so I'd only of had a few minutes there. Wanted to ask on availability dates etc ...
Would be interesting to try/buy one. The motor looks tiny on @aja07's video when you see the mechanic handling it like an apple.
Can't wait to hear you opine. Maybe @Rob Rides EMTB could bring you on as a guest muppet for the review?
what are the chances that:
A: the 750 battery will be backward compatible with 2020/2021 bikes
B: being able to buy said battery
Ahh, i just realized that the new Reign 2022 isnt available online on the UK Giant Website.... there you go guys:
Those are the 2022 Reigns:
Giant Reign E+ 0
Motor: Giant SyncDrive Pro2
Akku: 750 Wh
Fahrwerk: Fox 38 Factory / Fox Float X2 Factory
Antrieb: Sram X01 Eagle
Bremsen: Sram Code RSC 220/200 mm
Preis: 7.399 Euro
Giant Reign E+ 1
Akku: 750 Wh
Fahrwerk: Fox 38 Performance Elite / Fox Float X2 Performance Elite
Antrieb: Shimano Deore XT M8100
Bremsen: Shimano Deore XT M8120 203/203 mm
Preis: 6.499 Euro
Giant Reign E+ 2
Akku: 625 Wh
Fahrwerk: RockShox ZEB Select / Fox Float DPX2 Performance
Antrieb: Sram GX/NX Eagle
Bremsen: Sram Code R 220/200 mm
Preis: 5.499 Euro
Giant Reign E+ 3
Akku: 625 Wh
Fahrwerk: RockShox Domain / Fox Float DPS Performance
Antrieb: Shimano Deore M6100
Bremsen: Shimano Deore M6120 203/203 mm
Preis: 4.799 Euro
Remains to be seen if the UK will get the 750wh battery on the E+1.
So far, seems only Germany has that option, 625wh on E+1 in most other geos
:rolleyes:
I talked to local shop in US which is an actual Giant bike shop and he tells me that he only sees the 2 and 3 coming to US at this point. No 0 or 1. I dont know how official this is exactly though, but it would be a real disappointment for me.
Bizarre given that Canada is showing the 0, 1 and 2 ?
Can you turn off handlebar control assistance on Giant bikes? on the Levo this is very convenient to save battery, assuming that this new Yamaha can be pedaled from off @Rob Rides EMTB let us know ;)
    Join 43,172
