dragonsback79
Is the S2 is not coming with a 125 AXS ?
I got the expert level, so X Fusion.
I went with OneUp because they have the lowest insertion size to max my situation out.
AXS are some of the biggest/longest. The X fusion as well..
What dropper size did you end up with?I’m on a S3 and can confirm that switching out the XFusion with the OneUp makes a significant difference in lowest seat position.
I haven’t measured exactly but I feel way better on steep tech with the saddle position.
Can you link the discussion on the KSL with the small rear wheel?
I bought a 210 OneUp with the same idea but the insertion depth wasn't enough to make it work for me. I may go the 180 option. I'm 185cm tall with a BB to seat measurement of about 77cm.What dropper size did you end up with?
I measured on my s4 (170mm) and could get about 20mm more drop . With the lower stack height I could almost squeeze a 210mm one up there. Probably would be fine with 200mm.
I am considering going this route or getting a switch grade when they are released as I like the concept. I have hit the seat a few times on jumps when I am trying to get fancy. It’s a bit annoying
SwitchGrade Saddle Angle Control Technology
@dragonsback79 - This little beauty has been very handy, especially in tight e-mtb applications.
IR-1.2 Internal Cable Routing Kit | Park Tool
How is your extended pedaling height now with the OneUp?
I noticed this too.General reminder to check the tightness or torque on your swat headset (under fork crown/steer tube)
I started noticing a slight creak but not any noticeable play in the headset.
sure enough, the bolt that tensions the headset / swat system had backed out a bit.
cheers ?
@jcmonty - I’m also happy with the “middle” + “high” geo setting. I made this change mainly for climbing clearance, which it has improved.
“slack” + “high” - can’t wait to hear what you think of that change.
Cheers
Where did you get the info on the leverage change with the geo change?i didn’t expect as much difference in the kinematics. Less regression at the end of the stroke too apparently. Caught be by surprise for sure. It’s definitely a better climber in this mode.
I chatted up cascade components, but it makes sense too. (Egging them on to do a link For the ksl (not likely due to small volume). )Where did you get the info on the leverage change with the geo change?
Yeah it’s not going to be your “smash 8k vert as fast as possible “ bike. But man is it fun going down.Got to ride my friends Kenevo today. Felt more similar to my Enduro than it did my ebike. Really fun bike that I could probably get used to. Not sold on the low power/range yet though. I like having 2 full sized batteries for my EP8 Commencal and can get 8k’ (2440m) elevation gain without even thinking about conserving.
Agreed. Highly considering selling my Enduro + Commencal to get one as my only bike. I don’t like having more than one bike at once anyways.Yeah it’s not going to be your “smash 8k vert as fast as possible “ bike. But man is it fun going down.
Any thoughts on the coil as of yet?Rockshox Super Deluxe Ultimate Coil
We have an amazing RS service shop here locally that I like working with. The setup, custom tune and the fact that I can work with them on getting the shock just right, has been a good experience.
What would you like to achieve with a different link?I chatted up cascade components, but it makes sense too. (Egging them on to do a link For the ksl (not likely due to small volume). )
the curve shifts left a bit which pushes that regressive end portion off the curve and has more of the progressive start. Honestly felt like I had a new link
Also the bling factor of having an aftermarket link.What would you like to achieve with a different link?
I have the Levo, the Levo SL , and just sold my Enduro a month ago.
Rode my Kenevo SL yesterday for the first time, I ride in the PNW Seattle area, steep, techy trails.
The Kenevo SL its amazing for this terrain, had fastest time on every single trail I rode, and that was on the first try.
Having said that, I would not take it to the more cross country mellow trails, too much bike, Levo SL works good on those.
This bike rides even better than the Enduro on techy steep trails, super stable, plush and confidence inspiring.
So my recommendation, is depending on the terrain you ride, if techy and steep, this could be the best bike out there.
Uphill, plenty of power IMHO I kept turning it ON and Off to have some excercise because rode my second lap with my friends on regular bikes.How is the uphill? Im afraid this is too weak to climb real mountain compare to a regular levo. What's you thought on this?
I'm a gravity guy for sure but I'm lazy for the uphill. Im on the fence between ksl ans levo gen 3.
JF
I won't receive the new coil shock for another week or two.Any thoughts on the coil as of yet?
Unless you are over 200lbs and not in great shape. Then I would say it will be nearly as difficult to ride uphill as a normal bike when in eco mode, and you’ll drain the battery super quick when in Turbo.Uphill, plenty of power IMHO I kept turning it ON and Off to have some excercise because rode my second lap with my friends on regular bikes.
As long as you remember that it still helps double what you are able to produceUnless you are over 200lbs and not in great shape. Then I would say it will be nearly as difficult to ride uphill as a normal bike when in eco mode, and you’ll drain the battery super quick when in Turbo.
