Finally arrived & fitted. Rockshox Super Deluxe Ultimate coil shock.
Can't wait to give it a test run.View attachment 63118
Not to put a downer on it but keep an eye on the rebound eyelet. It cracked on my kenevo. I think this is pretty rare though, the superdelux seems way more reliable than the marz bomber.
Thanks for the heads up, will keep an eye on it.
These finally arrived, after seeing @JBel post about them, thought I would give them ago. I'll fit them this afternoon and let you know how they perform.
^^thats where im at. Put a progressive "race only springs" coil on my cc db. Only a couple rides but i think i "need" one on my enduro bike as well, and theyre noy cheap. Midstroke support is amazing in the rough or corners. No wallow and its still supple off the top. Need to hit more steeps and jumps/drops first to be sure. Put on some canfield crampon pedals too. Soo thin and soo grippy. Pretty much done until i decide where im going with a fork. Just maintenance for the time being/fsmous last words?
Irritattingly, I forgot to order foam seals etc. so now have a fork in bits until they arrive.
Maybe your old foam wipers are toast but i usually do 2 or 3 lower fork services with the same foamies. Spray them out with wd , dry and coat liberally with slickoleum does the trick
Yeah, that's true & I did that. Unfortunately these ones have stretched & won't reseat flush, they're just end of life really. No biggie in the scheme of things, I have other bikes to ride, I'm just champing at the bit to try the upgraded fork. The Yari is sweet but the small bump sensitivity is poor & exaggerated by the terrain round here. Patience is a virtue & all that.
After some battle scars i have ordered some replacement decals for my fox 38's now that i noticed slik are allowed to make them again and a booking for suspension servicing, a new rear cassette to go with the full drivetrain swap.
Get well soon. Good prepping for the return
^^i hear both the wolftooth and the pnw loam lever are butter smooth and a nice addition to any post. Friends were pleasantly surprised
I put some canfield crampon mt pedals on. So thin, so grippy, so durable. Added 2 rebuild kits in my order and rebuilt my 4 yr old ones, that i have on my meta. They werent bad but theyre like new now and i have a spare rebuild kit.
That backdrop sheet of plywood costs almost as much as my fave pedals
Not the most exciting thing I've ever bought but hey, at least I've chugged on to the point it's needed I guess.
I need one of those. Towing with my lawnmower pull cord yesterday works but in/out of the pack isnt the best. Any online retailers sell them?
Must be a bitch carrying the mower too ??
I made some out of paracord , larger loop to go over your saddle and slide down below the clamp and a smaller loop to hook under the clamps on the towed bike. Need to make more as I ended up giving them away to people I towed. Weigh nothing and get stuffed in a pocket.
    670K
