22 Gen 3 Levo - The cleaned posts.
Status
Not open for further replies.
Check this site for the Kenevo Prime thread. Sounds like the new Kenevo is going to hit on the 28th next week....
Anyone buying on todays US restock?
I almost pulled the trigger on the Blue S4......but i can wait for my Expert
That was my plan, until the pro showed up. Cannot...resist...my resistance was futile....I have to sell 2 bikes to fund it. Gen 2 levo is sold; will be selling my Ripley V4 next (collecting dust in my garage - just rode it for 200 miles).
not a bad choice considering you get carbon wheels and cranks
Does anyone know when the gen3 comp and base models will be released? How much price difference will there be between the current 5.5k and 7.5kusd?
All main dealers will take orders but when you'll get one who knows, mine is only one of two Experts coming too one of the biggest Turbo dealers in the country.
So at my local Spesh Bike shop one of the mechanics said that the Top Spesh rep that calls on them said to him that the new TCU will NOT be available to retro fit and in fact cannott be retro fitted into the ealier models of the turbo levo's. I told him my research said it CAN be retro fitted into an earlier model. What do you say turbo levo community? And I wonder if Spesh told the rep to dance around the question so as not to kill demand for the new 2022?? Can it work? AND if yes, how long will we have to wait? Thanks
It works at the moment, but Spesh says it won't work from the next update
From the Facebook Levo Kenevo group ;
Mike Fishing
Sounds like there is a market for a version called the ‘Hillbilly’. Just the minimum spec but with racks for the Banjo.
I can’t see the big difference between the 2022 expert and the Pro, other than that sexy red matte paint, jeez that’s nice! ?
Expert specs:
PRODUCT DESCRIPTION
The 2022 Specialized Levo Expert Electric Mountain Bikes delivers the unbelievable power to ride more trails through an unequaled combination of ride quality, usable power, and ride anywhere range. It’s the distillation, application, and amplification of a 40-year obsession with creating the world’s best riding mountain bikes. Since its introduction, Levo has set the bar every other e-MTB aims for, and the new Levo raises the e-bike bar again.
It starts with our Turbo Full Power 2.2 motor and MasterMind Turbo Control Unit (TCU), which provide Levo with a smooth and seamless amplification of your efforts—4x you power that lets you choose where to ride, and when you want to do it. Levo also shatters limitations when it comes to range, amplifying your effort for up to five hours of trail time. Now you can ride farther, and explore more, than ever before. And the optimized chassis boasts 150mm of custom-tuned rear suspension and adjustable geometry that delivers a stable and natural ride like no other. Because at the end of the day, it’s the ride that matters. Believe it.
Here’s where the gloves come off—the Levo Expert brings it with SRAM’s robust X01 Eagle 12-speed drivetrain, dialed-in FOX Performance Elite suspension, and a high-performing Roval Traverse wheelset.
  • Levo’s fully integrated Turbo Full Power 2.2 motor, 700Wh battery, and advanced MasterMind Turbo Control Unit deliver category-leading 90 Nm of torque and 565 watts of power for up to five hours of ride time, empowering you to ride farther and faster than ever before.
  • The MasterMind Turbo Control Unit is your information hub with customizable display fields, including the exact percentage of battery level, and it features our all-new MicroTune function to adjust power delivery in 10% increments, so you get exactly the support you need to experience precisely the ride you want.
  • A dedicated mixed-wheel size design with a 27.5” wheel in the back and 29” up front delivers a nimble ride that carves circles around other full-power e-MTBs. A generous cockpit centers you on the bike, optimizing traction and corner control. The low bottom bracket, slack headtube angle and reduced fork offset keep things stable in the rough.
  • Levo offers six distinct geometry settings, allowing you to easily dial-in its performance for any riding style andany terrain. Head tube angle can be adjusted between 63- and 65.5-degrees. Bottom bracket height can be fine-tuned up or down by 7mm.
  • Levo’s 150mm of rear travel is supple on small bumps, devours square-edged hits without a twitch, eats massive G-outs for breakfast, yet still offers amazing pedal response and delivers your power to the ground with total efficiency.
  • The Levo’s S-Sizing is based on what matters—rider size and style, not inseam. Six sizes, all with similar headtube lengths and standover, allow you to choose the size that best suits your individual style. Smaller S-Size numbers are going to be nimble and more flickable, while bigger S-Sizes deliver more stability and a roomier ride.
FrameFACT 11m full carbon, 29" front wheel, 27.5" rear wheel, full internal cable routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel, geo adjust head tube, geo adjust horst pivot
ForkFOX FLOAT 38 Performance Elite 29, Grip2 damper, 44mm offset, HSC, LSC, HSR, LSR, 110x15mm, 1.5" tapered steerer, 160mm travel
Rear ShockFOX FLOAT X2 Performance Elite, LSC, LSR, 2-position lever, 55x210mm
ShiftersSRAM XO1 Eagle trigger, 12-speed, single click
Rear DerailleurSram X01 Eagle, 12-speed
BrakesSRAM Code RS, 4-piston caliper, hydraulic disc, S/M: 200mm, L/XL: 220mm / SRAM Code RS, 4-piston caliper, hydraulic disc, 200mm
CranksPraxis forged M30, custom offset, 160mm - SRAM X-Sync Eagle, 104 BCD, 32T, steel
CassetteSram XG-1275, 12-speed, 10-52t
ChainSRAM GX Eagle, 12-speed
WheelsTraverse 29 / 27.5
TiresButcher, GRID TRAIL casing, GRIPTON T9 compound, 2Bliss Ready, 29x2.6" / Eliminator, GRID TRAIL casing, GRIPTON T7 compound, 2Bliss Ready, 27.5x2.6"
StemAlloy Trail Stem, 35mm bar bore
HandlebarsSpecialized Trail, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 30mm rise, 780mm, 35mm clamp
GripsDeity, Knuckleduster, Black
SaddleBridge Comp, Hollow Cr-mo rails, 155/143mm
Seat PostX-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SLR LE lever, 34.9, S1: 100mm, S2: 125mm, S3: 150mm, S4/S5: 175mm, S6: 200mm
Seat BinderAlloy, 38.6mm
*Specifications are subject to change without notice
Status
    Join 43,134
