My Decoy Leaning on Stuff
San Juan Trail awesome 11 miles of uninterrupted singletrack with a little bit of gnar mixed in!
I've got to come out there again once Covid is over. Perhaps next summer. Maybe stop in and see @TransAmMan on the way!
That'd be great. If you have a camper, lots of room to pull into the yard here. I recognize user name TransAmMan. Not sure where he's at. Is he in town here?
Where in Utah is that? How far from SLC? I'm thinking a road trip is in order once Covid is over...
It is in caineville Utah. Swingarm City. Not much for mountain biking to be honest, unless you want to push your bike up and then ride down some steep stuff.
Nice build! Is that a flow snap vee rubber in the front? How do you like it? What is the size and casing?
Thanks, yes that is a flow snap. Size is 2.6 enduro core. I had to change out the rear near the end of the winter.
I do like it for the summer and find it has lots of grip. In the winter it was good I thought but probably not the best out there.
Running a scorpion emtb s hy-wall in the rear after the flow snap and its not bad either so far.
Ok, thanks. I couldnt tell what the rear was
This spring has been amazing. Way less precip than normal. A few options have melted out now. Got my coil back from service, -1 degree works headset in and i should have the 180mm 38 on in the next couple days. Got onto a couple new steepies and found a couple more new ones to check out real soon, super long rock slabs. Word on the street is theyre the new man makers in the valley. Psyched!!
Nice. I am happy with my fox 38 180mm I've upgraded to. I decided to go with the none emtb version as it was the only one I could get at the time. I did not change the head set at all for it.
    Join 43,191
