I have to say that for me it looks better than the official Intense offering, congratulations on a very well executed build.
This is mint. Surprisingly "light weight" given the specs. I was expecting 30kg++++
Can you crank it up to a full 40a on the controller?
If I was you I would concentrate on the battery/enclosure as it is to me the most innovative part of that bike and would be relatively easy to fit to other like models rather than the Hailong style ones and way more stylish. I'd be your first customer!
100mm dropper, I'm out.
i assume u mean this type of battery?
ive made abunch of bike with that style of battery. i actually really like it, its cheap, easy to use , and fits well on alot of bikes.
No, this type of battery
I've got 3 HL type 2170 batteries already in 12/15/18 but want to get rid of the bulbous look and think that placement and potential universal application of such a type as yours would be just what I need, On my FS bike I have to only use the bottom bolt so I can tilt the mount enough to get the battery, 12ah, out and use a strap to secure the front. Works but not at all optimal. (and as close as it looks the sus beam clears the battery)
For that bike and how and where I ride it locally a 12ah battery is sufficient for the two-three hr. under 25mile rides I do. That's about all the offroad I need for the day. For longer missions on logging roads I use a front hub drop bar bike and for that I want more reach and toggle between the 15/18ah ones but would still benefit from getting rid of the wart.
Not sure how you made your case because I'm no engineer and especially dumb about plastic things like 3D printing/moulding methods etc.. But am smart enough to seek out help from others that are I guess. My perfect experience at this point would be to get enclosures made that I could swap out the cells/BMS into from my existing batteries......
I just can't believe how factory that looks. In fact, I thought it was at first. I think it's how well you integrated the battery that really wins it all. How you engineered even 'simple' things like battery retention must have taken a lot of thought and effort too. And 1600Wh...mental, but awesome at the same time. I would love a bigger battery than my 625, about a 1000 would be nice.
Brilliant conversion, awesome work!
1600wh is insane yes. but i mainly did it for battery pack life, not run time, but physical battery life.
the idea being that with 1600wh, each cell experienced half the wear/degradation as a 800wh pack, or 4 times less then 400wh pack.
but more importantly , it spreads the heat out amongst twice as many cells. so even with 1500w of power being pulled, each cell only pulls aprox 12w, which dramatically reduces heat build up. and heat is the #1 cause of cell degradation.
not to discourage you. but the frame u have will require alot more then just bending/bashing the frame. it will require cutting and re-welding if you are to fit the motor up high without it "Uttering".michael.kozera Your bike is amazing! I am putting a BBSHD onto an Intense M9 frame and it won't fit even with two chain guide tabs cut off, so I am about to try and do what you did to mount your motor. Without your post I probably would have moved onto a different frame, but with your inspiration I am about to start pounding away. Any advice, did you heat the aluminum or do anything to the frame before pounding and was there a best hammer shape or weight? I am a little apprehensive about ruining the frame. Thanks in advanceView attachment 58013
red circle is where the motor would go. and the 3 lines are where you would have to cut, and re-weld "reinforcement material". all doable by even a novice with general aluminum welding skills.
100mm is all i could fit.
100mm dropped has total length of 350mm and I had only 360mm to work with.
if i went to 125mm the smallest length I could find was 380mm. so bassically ,seat would be too high at that point.
On your build, have you taken any big hits to the motor housing yet? That's the aspect of the DIY builds that freaks me out. It just seems so vulnerable out there.
This is brilliant. I don't suppose I can pay for your services and have a battery made for my 951?
nodo you have a photo with that hole or cavity for fitting motor ?
I know this thread went dormant a long time ago, but thought I'd ask if the OP is still having the bike run well with frame adjustments. Truly an awesome build! In fact, I ran across this, only after finding the exact same frame, year, model, and even color. I did not do as extensive of cutting, and just to get my BBSHD motor to fit, I still needed to cut out the bottom. So was hoping to ask if I still require welding.
