SEBA
what is the format of graphics ?I don't like it at all, sorry.
how do you do these graphics ?
can I change graphics by myself ?
There is no way to change graphics by yourself. You can change display schemes and some colors onlywhat is the format of graphics ?
OK , can you tell us how you do these graphics ? I'm curiousThere is no way to change graphics by yourself. You can change display schemes and some colors only
Draw it using native vector graphicsOK , can you tell us how you do these graphics ? I'm curious
No. Android 8+does it work with Android 2.2 ?
A really useful side benefit of tracing what gears are used the most allows some prediction of gear wear over time... Most ebikes wear the smaller rear cassette gears first and would be nice to see a mapping of kms in those gearsLooks interesting
Not that I’m a big fan of a dash on a mountainbike, as i prefer to ‘read the trail’ instead. But what I find useful is to analyse the ride when back home. What I find very interesting is the app that SRAM has made for their AXS drivetrain. At the end of the ride you sync the AXS master with your phone app, and see the number of gear shifts, which cog was running and for how long. The app syncs with Strava and gives you the ability to seek out a segment where you can see which gear you were using etc.
I’d find a similar functionality useful, being able to see the telemetry for any given segment, like assist mode, power etc.
is there a similar option for and Android watch ?Apple watch support in the upcoming new version for iOS/WatchOS:
1. Heart rate from the watch
2. Connect/Disconnect, Start/Stop recording via Watch
3. Dash (there will be more)
Android watch does not have real-time connection with an Android Phone.is there a similar option for and Android watch ?
Please make a video and send it to me (PM or email)Excellent, love the Apple Watch +HR integration! So nice to have the battery percentage, etc., at a glance. Thank you for your work on this app!
I'm pretty new to the app (using iOS 14.4.2 on iPhone XS) but have noticed the duration clock on all of my rides starts at 23:00:00 and counts upwards. The time of day is recorded correctly. Is there a setting in the app (or in the bike software) to change this?
1. STRide displays the millage according your bike's millage multiplied by the correction factor (from App's settings)The other issue I have is that while the mileage displays correctly in the ST Ride app, after the ride is exported to Strava, the mileage displayed there is ~20% less. I'm supposing Strava is basing the distance on the GPS data alone and not the distance data corrected by the wheel sensor that ST Ride uses. Is there a way to export the corrected/measured distance data in the Strava export file?
Also, what Watch? And WatchOS version?I'm pretty new to the app (using iOS 14.4.2 on iPhone XS)
Can you explain this further? I don't understand your explanation. I did one ride, which should have maybe 2500ft climbing, but the "Climb" value is 84240 ft.Descent/Climb values are increments each time when GPS altitude is changed.
If you climbed 5m, then descended 5m and then climbed 5m again, then the result will be 10m ascent and 5m descent.Can you explain this further? I don't understand your explanation. I did one ride, which should have maybe 2500ft climbing, but the "Climb" value is 84240 ft.
Android app. I certainly didn't climb 84000+ feet ?If you climbed 5m, then descended 5m and then climbed 5m again, then the result will be 10m ascent and 5m descent.
Do you use iOS or Android App?
Export the session to STRide format and send it to meAndroid app. I certainly didn't climb 84000+ feet ?
I don't want to do this at this moment. Send to me your configuration (in any format) and I'll add it to Online schemes list@vadII - would it be possible to add configurability to allow users to select the data that appears on the dash & map screens? Not chage the format/layout, just the fields that are displayed.
All layouts are conifurable via XML schemes. They are available Online or you can make you own using text editor.(but I agree having configurable layouts would be a super good feature).
