Saw this EMBN video today. I'll use Turbo for giggles when I can, not all the time though. How often do you lot ride in Turbo?
I went for a 45 minute blast today. Majority in Turbo. Had loads of battery and not a lot of time. Got a good workout too.Saw this EMBN video today. I'll use Turbo for giggles when I can, not all the time though. How often do you lot ride in Turbo?
What Rob said.I went for a 45 minute blast today. Majority in Turbo. Had loads of battery and not a lot of time. Got a good workout too.
Hi Tim, Blevo already does this and also the Battery temperature ?with all the apps available for the specialized i would push for the app developers to tap into thermo sensor and monitor it. Without a display you can’t see it but if you could record it or see peak numbers you could then analyze your ride and ambient temp and figure what is safe, how long you can run hard and not go into thermo protection. I know for 2019 they have added a heat sink to the motor to help the problem.
I know of 4 people in last 6 months that have had a motor failure in there levo or kenevo, but i also know that all 4 where hacked and no assist limits. I see temp gauges in ebike future.
I put a temp strip on my bulls and on a 100 deg day climed 4 miles on a 8% grade and noticed a significant reduction in power by time i got to top. After pulling side cover the temp strip showed 210 deg, that’s pretty hot for the alum side cover of the motor. I do not have any info on how much heat they can withstand without thermo breakdown.
I’m not positive but my bulls has 1200-1500 miles on it and it’s brose T drive. I have not done the temp check on my Fantic as i have only felt it reduce power once. But it has the S drive and i don’t use high power as often as it’s noticeabley more power then T drive.
The levo and kenevo both go into thermo protection mode after 10 min on a 75 deg day, and it reduces power, i would think that if your constantly going into thermo protection the motor be slowly breaking down from heat. But how much heat does it see i haven’t tested and i don’t know the temp specs they will withstand in comparison to when the thermo protection depower scale.
So is it depowerinf well bellow thermo damage occur’s or is it right at the threshold of failure??
I can’t get that info from Brose.
The other factor is all the blue tooth tuning does any of that throttle back the thermo safety??
See my screenshot below
Not sure what the upper limit is, but.... @Specialized Rider Care may be able to assist us with the answer to this question?What is the safe upper limit anyone knows?
Does the display temp boxes change colour when is getting near the upper limit?
can you do a climb that is over 8 min long on a grade where u climb more then 500ft in a mile. After you have done a few miles in turbo mode.Not sure where you are getting your figures from Tim but on a 75 degFh day my motor runs quite happily between 30 degC - 86 degFh and 42 degC - 108degFh and higher without losing any power.
I know I am not losing any power as the maximum power output is constantly being displayed ‘live’ on my display on my ride. I have a 1.2 motor and this pushes out between 640-680 Watts while I am riding in Turbo mode. The 1.3 motor, I have seen screen shots from the other forum members of between 720-780 Watts.
The only time I ever see my max output power going down is when I am riding my bike on Turbo and the battery level drops under the 40% mark.
This is why I find Blevo soooooo good, it pumps out all this, and for me, really useful info and loads more.
I need to do some more testing on this so I can capture more accurate info for you.
Can
I will get the blevo app and see if i can connect to one of my riding friends bike and see what is throttling back here bikes
I think everyone i know that is throttling back is hacked in some way, they all don’t have speed cuts. There no speed related assist cutoff.all levo motors are fitted with a heat sink well at least the alloy frame ones are there is a thermal pad in contact between frame and motor.
I monitor my battrey temp and motor temp with BLevo but I can say I have never seen very high numbers and I can say I have not noticed any power drop, well maybe a little but almost unoticable unless the are watching the BLEvo display for motor output
there is a lot of nonsense talked about bluetooth apps and what they can and cant do
what they cant do is increase motor power and lets remenber the restrict threshold is different from country to country, the highest I believe in New Zealand so if spesh deem it ok to run the cutoff point higher there why is it not ok from a motor manegment point of view elsewhere!
