Why so? You can always keep your 5€ 8bit nintendostyle purion and resist the evil changes that Bosch does developing their electric bike ecosystem.Bosh is going the wrong way, isn´t it!?
complicating rather than simplifying.![]()
If I accidentally change to EMTB mode during technical slow trail I notice it immediately as much more stronger torque. I would say that EMTB Lite is not just max torque cutoff. The power curve must be some way different.I havent tried this but on paper If you ride a lot in EMTB mode it would seem to make sense. If you spend most time in Eco or tour maybe not so much?
Don't be worried with battery drain in emtb lite.Good info in this thread thanks - If you like to pedal a bit isnt this going to be a much bigger drain on the battery than just having tour?
If its the same as EMTB mode then it will kick into max support (240%) from 125 watts ( i might be wrong on that figure) which is fairly low. I think id just be smashing round @ 240% support all the time, as thats less than a 1/3rd of my ftp! Its a nice addition IMO but not at the expense of tour!
I think it should have had a 50% – 200% range to replace tour rather than 140%-240, or...... not replaced tour at all and be an additional mode
I watched my dealer do the software update.
They are both.Was that a Trek dealer or just a Bosch Service Centre? I will struggle to get to a Trek dealer but do have a Bosch centre local to me
Aah, I'm trying to figure out if a NON Trek dealer, albeit full BOSCH service centre can do the update, thanks anywayThey are both.
Trek seem to advertise it as thier own mode , like they’ve worked with bosch . I wonder if there’s some kind of copyright etc to keep it trek only ? Surprised your new model didn’t have it , when did you buy it .Aah, I'm trying to figure out if a NON Trek dealer, albeit full BOSCH service centre can do the update, thanks anyway
Interesting on the software numbers , I’ve not found /looked for that . Do you know what the update number should beIt arrived 2nd week in December but going through the Kiox shows software 1.0.2.0 & hardware 0.0.6.0
In my phone app it says I have software version 3.0.1.0. Hardware 1.0.0.0I'm not sure what the revision will be with the eMTB Lite. If you get chance can you post your numbers if you would?
there are a few choices when doing the update. The choices for the 85nm update I believe were sport, emtb lite, or tour.
i took that as
-sport replaces emtb
-emtb lite replaces tour
-tour replaces emtb lite
Under Drive unit says software version 1.1,2.0 Hardware version 0.0.6.0Hey mister,
That is the Kiox software, if you click on your bike icon just below that, then Drive Unit that is the motor firmware software there.
New Zealand uses the same version of the software as the USA with the 20 mph (32 km/h) assistance restriction and I've had it on my 2020 9.8 Rail since before Christmas. Do a quick check in a ride round the carpark at the bike shop when you pick it up and if it doesn't have it, get them to update it then and there; it only takes a few minutes.Hey All, any riders in the USA that have gotten the eMTB lite ? I hope to take ownership of a 2021 9.8 XT in mid Feb and want to make sure the bike has this new coveted mode![]()
Did they say what the max torque is? Tour mode is 50Nm.
I took my Rail 7 in to my supplying store for a dropper warranty claim at the beginning of december, i asked them to plug it in for any updates and they put in the new emtb lite version(works like emtb but less torque) after this i ran out of battery on 3 rides!!!! :<( between christmas and new year and asked them if they could return it to its stock settings 85nm after explaining wot the sketch was, and now its back to big miles !!I spotted on the Trek site a Custom eMTB Lite mode to replace Tour mode, has anyone used this yet? Is it a firmware update?
Wow! this is the first I've read of less time. Most reviews are more time. Was your finding using all modes or just the new one?I took my Rail 7 in to my supplying store for a dropper warranty claim at the beginning of december, i asked them to plug it in for any updates and they put in the new emtb lite version(works like emtb but less torque) after this i ran out of battery on 3 rides!!!! :<( between christmas and new year and asked them if they could return it to its stock settings 85nm after explaining wot the sketch was, and now its back to big miles !!
At first I thought it was brilliant , then I set off on a big mileage ride ( 35+ miles and 4K+Ft) climbing, ran out about 3 miles from home, luckily it was mostly down , but the last 20% was very little assist( felt like just eco)!Wow! this is the first I've read of less time. Most reviews are more time. Was your finding using all modes or just the new one?
So how fewer miLes were you getting on your regular ride. I’ve just been out to try and run my battery out just to see how it behaved in the last few percent , it nearly wore me out , almost 3 hrs of our hardest climes and descents in emtb and turbo Lots more than the old shimanoWow! this is the first I've read of less time. Most reviews are more time. Was your finding using all modes or just the new one?
Something is not right here. Actually nearly impossible to believe that lower torque/ assistant mode could ever cause this IF functioning correctly.I took my Rail 7 in to my supplying store for a dropper warranty claim at the beginning of december, i asked them to plug it in for any updates and they put in the new emtb lite version(works like emtb but less torque) after this i ran out of battery on 3 rides!!!! :<( between christmas and new year and asked them if they could return it to its stock settings 85nm after explaining wot the sketch was, and now its back to big miles !!
Yes the update is available in the USA.Hey All, any riders in the USA that have gotten the eMTB lite ? I hope to take ownership of a 2021 9.8 XT in mid Feb and want to make sure the bike has this new coveted mode![]()
