Portable pressure washers
Just tested mine. It's very good, plenty of pressure if required. I bought the one with the additional accessories so I can foam wash. It came with 2 x batteries which was a pleasant, unexpected surprise. All I want now is a case to carry it in otherwise I can see the bits getting scattered round the boot. The cardboard box won't last very long I suspect.
Sorry which one?
So really isn’t this just a waste of energy? Your doing the same job twice almost or 1.5x, then needing water, lugging around, more space needed......
why not just get a 1m x 4m DPM 300MU Damp Proof Membrane Polythene Sheet 1200 Guage Visqueen under a tenner for the boot, take bike out wash properly once only, lube up and you’ve saved time overall and water......
as for muddy items we could bag them up and wash those too but luckily seem alright in the washer so far!
I bought the worx one with brushless motors..can't remember the model number..only really any good for mtb,my motorbike and the garage door n facia...could do the car but it would be to much like hard work
+ 1 for the Mobi. Works well with hot water.
Spray. Muc Off Spray.
Just angle / deflect off any bearings or sensitive areas.
Works on riding kit and shoes as well.
it’s called Outdoors GPS. Gives you the complete OS map of U.K. on your phone. Ability to plot routes and record your journey. It’s the only app we use for our bikes.
Can you select trails uploaded by others? Have you tried Trailforks?
yeah if you have a PC you can.
I’ve not tried trialforks. I’ll look it up
Trail Forks... you drag one along and it's easy to see where you've been so you can find your way back ..
Can anyone make a personal recommendation? I've seen a few reviews but remain none the wiser.
Please resist the temptation to lecture about the wisdom of using a pressure washer on an e-bike. I am aware of the risks which is partly why I'm looking for recommendations. Small is good, I only want to wash one bike at the park before putting it in the car. Both battery and plug into 12V lighter port would be good. I'm currently using a Hozelock 1.5 litre manual garden pump but I don't think it will be up to the job of winter mud. I'm also thinking that if I'm taking time to clean the bike at the bike park I might as well do a thorough job and not have to do it again when I get home. To date I've looked at:
Karcha OC3
Jetwet
Mobi V17
Worx Hydro Shot
Al
I got Mobi V17 a few weeks ago. Really handy to get the worst of it off before getting home. I’m really pleased with it but to do a proper job you will still need some sort of cleaner and brush etc. it’s not the most powerful but that was the selling point for me. Only used on battery so far but does have 12V power supply too. Does the job ??
See this is where it falls down, surely these days there’s something to rock up with, scan, play.....
Essentially that is what you do with TrailForks, you don't "need" a PC. The PC simply makes it easier to view and edit at home.
We like the detailed mapping on the Outdoor GPS app. Basically use it to create our own routes for exploring and finding shortcuts. Use old iPhones which we keep on the bikes and use airplane mode which lasts a whole day. No data is needed once the UK map is downloaded.
I think they all come with a battery but I did buy a spare battery which was cheap as chips. It is an Erbauer 18v 2.0 Ah.
many of these type of batteries look almost identical but there are subtle differences in the connectors which mean they won’t fit so be careful when buying a spare or alternative battery
Different apps have different strengths and weaknesses. I wouldn't use TrailForks to plan a route for example but I might use Komoot and/or OS Mapping. TrailForks, however, is brilliant for finding established trails.
Ordered a Hydroshot from Amazon £78 c/w accessory pack and battery.
It will come in useful at home, not just on bikes, so will give it a go.
Be careful, some of the listings on Amazon are bare unit only, without battery.
The speed at which it can clean a bike is awesome ?
Even use it to clean MTB shoes in seconds
Shame they can't dry MTB shoes as well.
I melted the insoles of my Giro's on Friday, trying to dry them with a fan heater.
Ive used these cheap Slazenger Warriors (£17.99) for over a year and good as new. quick blast with hydroshot and job done. Never had wet feet, even when blasting them with a pressure washer ?
Decent discount on the Worx Hydroshot today at Amazon
WORX WG625E 18V (20V MAX) Cordless Hydroshot Portable Pressure Cleaner
The next one up looks better value for just £10 more......but instead of 1hr charger it’s 3-5.....hmmmm
I might get one but I still don’t see the logic in doing more work rather than using a visqueen sheet and doing the job once properly when your back to base, fair enough if you did a full clean on site and then lube it when home but you rinse down once, towel it down then repeat again, plus the need to carry a big tub of 4lt space....am I missing something?
Yes you are missing where I said I carried the bike in the car, wanted to get the mud off before I put the bike in the car but didn't want to start over when I got home. In fact the whole point of my question and this thread regarding portable washers :)
That was meant to be amusing not sarcastic. Apologies if it came across that way.
I found it amusing because it was sarcastic, I can even image you rolling your eyes as you typed it. :D
I had a mobi V15 till a fellow rider not really a mate ? accidentally stood on hose exit snapping it off, was pain finding replacement so got a hydro shot, night & day better than the mobi, more powerful, if have no water can put hose in puddle/stream etc to clean bike, also turn up pressure to clean van. Mine broke after a while, wouldn’t suck up the water from the container (bought 20l container off eBay) so contacted Amazon they sent out new one & sent old one back in sale box, new one still working
    673K
