Focus jam2 6.7 Plus 2020 v 2021
8,694
Thanks I have and it’s not very clear - some places still have 2020 models specs
Retailers and manufacturers have a lot to answer for. They should, as a minimum, make sure that their sales data and specs are up to date and accurate. I have found old geometry charts purporting to be the latest, when I knew they were supposed to be different. Another one was where you get front and rear tyres listed as the front and a second set listed for the rear. I can see what they've done, but it is just sloppy!
  • Front Tyre - Maxxis Assigai WT, TR, 27.5" x 2.5" 120TPI, EXO+ casing, 3C Maxx Terra, Dual Compound, Front, Maxxis Minion DHR WT, TR, 27.5" x 2.5" 120TPI, Double Down, 3C Maxx Terra, Dual Compound, Folding Bead, Rear
  • Rear Tyre - Maxxis Assigai WT, TR, 27.5" x 2.5" 120TPI, EXO+ casing, 3C Maxx Terra, Dual Compound, Front, Maxxis Minion DHR WT, TR, 27.5" x 2.5" 120TPI, Double Down, 3C Maxx Terra, Dual Compound, Folding Bead, Rear
I was unable to buy a Charger 2.1 damper from one UK company because the description conflicted with what Rockshox said it was for. By the time I had sorted that out, the Charger had been sold and I had to get one from a German website and I lost another 10 days. The German website's description was wrong too, but by that time I knew enough to see past it.
It is hard enough to buying expensive tech and kit, without the sellers making it harder still.
Walkea
64
39
Glasgow
On Focus website scroll down to footer at bottom of page and click link for archive models that will let you see manf spec for 2020 version or older.
525K
