2019 Specialized Turbo Levo News & Rumours
Status
Not open for further replies.
BeBop
20
53
Euroland
Looks like the LED bar we saw on the top tube a few days ago.
Kiwi in Wales
Short cranks rule!🏴󠁧󠁢󠁷󠁬󠁳󠁿
1,240
1,588
Carmarthen, Wales
Found the following specifications on some random Kiwi site.
Ohlins Piggy back coil shock 160mm travel
Lyrik dual position 150mm to 180mm forks
SRAM Roam 60 30mm internal width rims
Magic Mary 2.6 DH Ultrasoft tyres
170mm OneUp dropper
800mm carbon bar
Shimano Saint brakes with XTR levers
REVGRIP Soft grips
137mm length Kris Holme cranks
Picture below, if these are the actual specs then this is going to be one hot machine ?
Slowroller
494
496
Wyoming
Bosch's is new motor is supposed to be pretty special but you won't see it for a year, it'll be on the 2020 bikes.
2020??? Geez, what a tease! I was expecting to see them on 2019s. Or do you mean just on Specialized?
neils
201
114
Wokingham UK
The new motor is ready to go but Bosch have to give the bike companies time to sell off their stock of current frames and 2019 was too soon for most companies. So you'll see it on the 2020 bikes. Sorry I don't know anymore except for it's a fair bit smaller.
neils
201
114
Wokingham UK
You keep saying Bosch, don’t you mean Brose?
No I don't mean Brose.... sorry if I'm input this into the wrong post, it's just we're talking about hidden new developments by SBC so I thought some may of been interested to know about another hidden development by another company producing something new and exciting :)
jemen
317
379
Austria
170mm OneUp dropper
800mm carbon bar
REVGRIP Soft grips
This is an old custumized LEVO, what should we do with that?
j.
BeBop
20
53
Euroland
Full Specs
  • 2.1 Rx Motor (Brose Mag S, 15% smaller 11% lighter)
  • 150mm Rear travel
  • 150mm Front Travel
  • 700Wh Battery, almost 40% more range
  • 29" Wheels
  • 2.6" Tyres
  • 10 led with charge status, 3 led with mode of operation
  • 160mm Dropper
Only the Expert and S-Works have the new motor and battery.
Pricing TBC, however possibly:
  • S-Works: €9490
  • Expert: €7290
  • Comp Carbon: €5790
  • Comp: €4890
"The design includes our 29 geometry trial that features a low bottom bracket, long top tube and short stem. the geometry of the ride has also been perfected. The cable guide is completely internal including that of the post post IR seat post, the battery is completely integrated in the lower tube, while the minimalist motor is mounted in a more secure and lightweight'
It has carbon frame of sidearm design, like the one you will find in the new Stumpjumper, 150mm of travel. Rx custom engine redesigned, a new battery of 700 Wh and a long list of features that make it the best trail bike, with even more energy. The power to travel more trails is yours."
ernstal
14
31
Austria
Full Specs
- 2.1 Rx Motor
- 150mm Rear travel
- 150mm Front Travel
- 700Wh Battery
- 29" Wheels
- 2.6" Tyres
-10 led with charge status, 3 led with mode of operation
I guess this is about the s-works version. Someone in an italian forum said, that the price will be about 12.000 euros for the s-works version and about 8000 for the expert version.
So, the 700Wh battery might be just in the expert and s-works model, with just another type of battery cells? So I guess, the 500Wh (or 630Wh?) battery will be in the comp models and hopefully compatible with the 700Wh battery.
Doomanic
🛠️Wrecker🛠️
8,490
9,970
Otherwise it's just speculation
Seems perfectly adequate in a "rumors" thread.
Unfortunately, there have been far too many baseless claims in this thread for me to get excited by a claim than cannot be backed up in any way. Besides, this is the Levo thread. Perhaps a Bosch thread should be started once there is some evidence.
Doomanic
🛠️Wrecker🛠️
8,490
9,970
12 grand for a bicycle!!!
How much are the Bulls bike again?
ernstal
14
31
Austria
Guys, then .... certain news, no ifs, ands or buts. Prices from 5,699.00 up to 12,000.00, frame like the new stumpjumper, all only 29 ", 3 colors for the comp, 2 for the expert, one for the s-works 504 battery for all, expert and s-works 700, not compatible with the old, new Brose engine lightened by 800 gr, larger torque, smaller and mounted in a different position, for the new batteries that remain hidden in the diagonal tube.Control on the central tube, a short aftermarket a dedicated computer. Clearly also new settings for brakes and gearboxes, on September 15th should appear all on the site.
Another quote of a specialized info folder, google-translated:
We know that we like to use the "totalmonte nueva" line a lot, but hey, were really excited. Well, actually we are excited to share things that we consider revolutionary. Without a doubt the S-Works Turbo Levo FSR 29 is by far the most prominent element in our range. It has carbon frame Sidearm design, like the one you'll find in the new Stumpjumper, 150 mm.
Rx. motor custom-designed, a new 700 Wh battery and a long list of characteristics that make it the best trail bike. With even more power. The power of riding more trails is yours. The S-Works Turbo Levo frame is built entirely in carbon fiber FACT 11m, which makes it not only light but also rigid and sensitive.
The bike includes our Geometry 29 Trail that has a low bottom bracket, short stem. The kinematics of the ride has also been perfected, using on the necessary rigidity.
The cable guidance is completely internal, including the Post Command Post IR the battery is completely integrated into the down tube. While the minimalist motor mounts in a more secure way and light Specialized 2.1 Rx Tral-tuned custom engine is more efficient, 15% smaller and 11% lighter than its predecessor.
It has many other characteristics that none to engine technology that another electric bicycle can dream, like the instant operation, the fantastic heat management. the double free-pin design that unhooks the box gears uniform, even at maximum power when you reach the maximum speed and a silent, smooth and The new Turbo Specialized M2-series battery has 700Wh capacity providing you with 40% more capacity and range, and even more power to travel more trails.
And of course, it integrates seamless in the tube and is removed easily.
rmh1009
234
97
West Wales
This is a google-translated quote of an italien forum:
We know that we like to use the "totalmonte nueva" line a lot, but hey, n we excited easily iMira, a squirrel Well, actually we are excited to share things that we consider revolutionary. and without a doubt the S-Works Turbo Levo FSR 29 os by far the most prominent element on our list. It has carbon frame Sidearm design, like the one you'll find in the new Stumpjumper, 150 mm Rx. motor custom-designed, a new 700 Wh battery and a long list of characteristics that make it the best trai bike. with even more energy. The power of Walking more trails is yours. . The S-Works Turbo Levo frame is built entirely in carbon fiber FACT 11m, which makes it not only light but also rigid and sensitive. The disono includes our Geometry 29 Trail that has a low bottom bracket, tube short pods. The kinematics of the painting has also been perfected. counting on the necessary rigidity. The cable guidance is completely internal, including the Post Command Post IR the batoría is completely integrated into the tube lower. while the minimalist motor mounts in a more secure way and light Specialized 21 Rx Trad-tuned custom engine is more efficient, 15% more . small and 19% lighter than its predecessor This places it higher as soon as of e-bikes. It has many other characteristics that none to engine technology Another electric bicycle can dream, like the instant operation, the fantastic heat management. the double free-pin design that unhooks the box gears uniform, even at maximum power when you reach the maximum speed and a silent, smooth and The new Turbo Specialized M2-series battery has 700Wh capacity providing you with 40% more capacity and range, and even more power to travel more trails. And of course, it integrates seamless in the box and is disassemble easily.
So the base model comp is over £5000? ?
Status
525K
