Levo SL Gen 1 Official Levo SL Thread
Anyone know what magura mounts I need for fork and frame on the comp ALU? Mt7, 203mm rotor front and 180 rear. TIA
This is the one I used on my front fork Fox Rhythm 34:
Magura Disc Brake Adaptor Qm42 6" Pm Front to 203mm Rotor. Others which are for a 6" / 203mm will also work. The back, since it is 180mm will use the same setup as your bike came since it was already 180mm in the back.
I’m back on an eeb. After hating them due to my problematic FF levo, I’ve gone full circle ish and picked up my SL today. Few more upgrades to come but many thanks to infinity cycles in Durham for sorting everything out. My mega tower may become a clothes horse lol
Mate your gonna love it. Perfect bike for you I think..Get a range extender and your Golden all day for any ride with FF bikes..
Well happy for you buddy ?
There was also some mistakes yesterday?? Right hip is a bit sore now ??
Video Quality is pretty bad, are you recording it at low quality or uploading it to YouTube like that? I’m starting to record rides but haven’t figured it all out and really dont want to subscribe to gopros cloud crap..
It looked like the ground just grabbed you!
Check it later today as youtube process its quality. It was fillmed with 4k. You need to change the quality by yourself
Check later as youtube processes it. Filmed with 4k like others above
Has any one striped down the rear hub on the stock roval wheels?
My freehub is crazy loud and I want to have a look to see if they forgot to grease the ratchets (I've seen this missed before on other bikes). So far I have got the end caps off but can't get the actual freehub off to take a look inside.
It’s a doddle to get in the free hub.
Removed casstte. Hold the axle on none drive side. Look which way the arrow points saying loosen on the free hub and turn while stopping the other side moving. When that’s come off the free hub just pulls off.
just re read your post and see you’ve got the end cap off. My free hub just pulls off when end cap undone
Took her down some steeps today!
Thanks for the reply, yeah i got both end caps but the freehub will not come off with moderate force, around the freebhub looks like a captive ring with 4 post holes so maybe this need unscrewing first?
Yes, unscrew that ring to remove the freehub. I used DT Swiss grease, that quietened things down a little.
^^^^ I'm on 2.3s (Butcher/Eliminator) and was about to post to see what pressures folk are running them tubeless. I weight 80kg and have them at 25 front and 27 rear, but think I may drop them a bit.
I did run 2.6 butcher/purgatory with 21 psi front, 22psi at back with panzer insert. Loved that combo.
Now tested the minion dhf 3c maxxterra at front, 2.3" at 24psi. At rear minion ss 2.3" at 25psi,both with panzer.
Have to say that liked more the butcher/purgatory and will go back to that.
Thats a lot of pressure. I’m at 20 rear 18 front. I am running cushcore. But even if I wasn’t I’d be at 22 rear 20 front
Wow that’s hard. Try 22 and 22.
Orders cain creek coil for the sl Di I need hardware or can u use the one out my fox dps if not any links to what I need even the shop don't know what I need ?
    668K
