Levo SL Gen 1 Official Levo SL Thread
Has anyone same thoughts that sl rattles more than ff levo when ride gets rowdy?
Mine rattles quite a lot when bombing rocks and roots ect,where the ff remained very silent.
What can cause it? Other than chain?
Are you running guide brakes? Try taking the caliper off and shake it. Just swapped mine out for XT and the rattles have gone.
There ya go. Next ‘Florida man’. Drunk guy using ebike to climb and jump toll bridge. Clears sailboat then robs a liquor store.
Reminds me of a sign on a greenway in NC. Obviously someone must have tried it to get the authorities to hastily post this sign.
Mandatory e-bike content: I didn't have an e-bike then but sure wish I did after 30 miles of 90 degrees/90% humidity.
my SWAT tool is making alot of noise in mine, also there is alot of cable slack under the TPU could be that too.
I have found a genuine reason to own the SL.
Its not handling, Climbing or other silly stuff like that......
Its......
Putting an ebike on a bike rack!!!!
so true! The SL's weight was a big factor for me. I use a Yakima roof rack on an Audi A4 and lifting the SL is very do-able and within the rack's weight capacity (barely).
Anyone gonna get one of these?
I have it paired with Push ElevenSix coil shock.
Stock travel length? Was it a good upgrade? You’d have to ride pretty hard to bottom the bike out at 20% sag.
Yes, stock travel length for the shock, and I flipped the chip. Altogether it works well for me, I like it. Can't tell much on the progressiveness of the Cascade link since I installed the coil shock at the same time. I'm an intermediate rider at best, haven't bottomed out but I'm not hitting big jumps or drops either.
Yes, I installed it ~3 weeks ago. Rode it for a week with the stock Fox DPS Performance shock while I waited for my Cane Creek coil shock to come in. I plan to try flipping the chip to see the difference, but at this point I like the linkage. Like flippn, I'm not hitting big jumps.
Mine rattles on rough stuff,a metallic sort of sound. On investigation I can only assume that the noise is created by backlash in the internal gears as it doesn't happen when pedalling in really rough stuff. I have gone down the route of 'if it's an issue it'll break and get fixed on warranty'.
Hi did you get the drive train and brakes changed ? If so did you get a decent deal on it
Thanx
yes but the rear cassette had to stay SRAM as did the discs. Shimano discs are centre lock so only the levers and calliper were changed for SLX. The free hub couldnt be changed either to take the 12 speed Shimano cassette. Still all works really well and the brakes are great.
Just ordered a Levo sl comp carbon. Will be switching to a full xt drivetrain and brakes and praxis carbon crank with light wheels carbon wheel set with I9 hubs. Plus range extender. Probably 2 weeks till ready to ride.
Congratulations! Like my LBS manager said, "try riding it as is for a few weeks to see what you really want to change.". So I did, then after that I started making it the way I wanted it. :) To clarify: the drivetrain is meh but good enough that I don't see spending $100's to change it; the brakes are ok (for mostly flat terrain); losing a few grams on the crank is not worth anything to me; I went with 27.5" wheels and dropped a couple pounds right there.
As always, YMMV.
Can’t stand SRAM shifters and I want decent brakes. The rest is just bling. I’ll probably use Renthal bars I have around and maybe a DVO Diamond fork and shock after I try what’s on it.
more of a creaking but i was getting ridiculous noise from the seatpost area , i tried greasing the collar thread but what got rid of it was using a different shim , a problem solvers 30.9 to 34.9
Hello, this forum has been great. Ordered my SL 5 weeks ago and broke my leg 4 1/2 weeks ago on my 18 Levo Comp Carbon FF. Decided to do a serious build on the SL which resulted In me getting another SJ Evo frame and some cranks as I had all the stock SL parts and no use for them. Now I have a sellable analog bike. Anyhow, doc says I can pedal carefully and easy. I’m super excited for this thing and rode it to work this am. Cannot wait to be healed completely! It built up 36.5 lbs with a Fox 36, DPX2 and bigger rotor in the rear. I just can’t wait to ride. Thanks for all the posts. -Andy
shim? Why is a shim required?
Love it, i have the same colour and always wondered what it would look like with a gloss finish as the Matt paint is hard to keep clean, now i know :)
Big hits, mine is relatively quite. Smaller chatter, the break pads/spring rattle in the caliper is really loud. Like, i though my headset or fork was broken. Mostly in the front caliper, less so at the back.
Spreading the pad spring thing helped a lot, but it's still a bit noisy over certain terrain.
(Expert, with SRAM G2)
Just ordered one from the UK store - cascadecomponents.co.uk. Been hoping this solves my issues with blowing through travel to hard while still having some small bump performance.
hi new SL owner here purchased a new comp carbon black-gunmetal in large a week ago from freeborn in horsham, put 120 miles on it. Was a previous 2018 turbo levo carbon comp owner for two years. Just thought i would share a few initial thoughts and some upgrades i have made may help someone whose thinking of buying or already has one.
main use long rides to coast and back along bridal paths railway lines plus big loops cross country so I'm setting this up to be as light and fast as possible but being capable going to the likes of surrey hill if i choose.
little about me 56yo 100+kilos not great fitness (ride mainly in eco 25%/100%) getting 60km with about 40% remaining is just about right amount of effort for getting fitter for me.
couple things I've noticed so far this bike gives me the chance to ride with fit acoustic bike riders 30y olds at a good pace, the cut off point is not hardly noticeable unlike my old levo. i can climb hills which i would normally be pushing up on normal bike but still having to put some effort in. getting to the brakes guide r was so under whelmed with them was thinking about swapping them out for something new but had a couple of ice tec 203mm rotors with mounts + brought some disco pads (copper free) now they have gone from lever pulling all the way to bar s and pretty vague. to firming up the lever and bit point somewhere near shimano feel they are as good now as guide re on my old levo and with not even having to re bleed them.
upgrades so far:
dt swiss h1900 already had
203mm ice-tec rotors front and rear
nuke proof carbon bar + horizon 50mm stem
sram eagle gx cassette & rear mech
vittoria barzo 29x2.6 (in a few days)
Quick note of thanks to all who post here.
I posted a few weeks ago while I was demoing an SL. I’ve had my new SL for a week now, and just yesterday sold my ‘19 Levo Comp.
Very happy with the switch as the SL fits my riding profile much better than the Ffat Levo did.
Perspectives here and the SL videos I watched got me to try one.
Thank you!
upgrades so far:
Nice one dude. I just put on some Disco Brakes Kevlar and super impressed with them..
Yeah - I was their prototype tester. we needed to remove some material from the stump jumper link
It does the job - better small bump and if you have similar sag , better bottom out . Just be careful to check clearance at bottom out. We found that some chain stays may be tighter than others if you have modified anything on your geometry (offset bushing).
I ran about 20 psi (10%) more pressure due to the higher leverage ratio
Thank you!
Tahoe?
I’m back on an eeb. After hating them due to my problematic FF levo, I’ve gone full circle ish and picked up my SL today. Few more upgrades to come but many thanks to infinity cycles in Durham for sorting everything out. My mega tower may become a clothes horse lol
    Join 43,210
