ichauchtt
I have the following issue on my YT Decoy. It all started with error code W011 (speed cannot be read). I removed, cleaned and reinstalled the speed sensor, magnet and everything looks good and undamaged. The result is that the error disappeared, however, the correct speed is only shown as long as I am pedaling. When I stop, the speed display starts jumping up and down and eventually goes to 0 kph. The distance is also not measured correctly.
The bad thing is that the motor on the YT is mounted directly to the frame, I would have to remove the whole motor to get to the connectors. I talked to YT and they said that I should not try to remove it myself as the warranty would be voided.
This behaviour is very strange, how can the speed only be measured when I am pedaling? If it would be the sensor or cabeling, speeds would always be wrong or not shown at all?
Anybody came across a similar issue or has any hints?
