2021 Kenevo spotted!
bajaboy
Washington
That’s just a bolt on conversion motor to a specialized demo unless I am mistaken.
I thought exactly the same,....and the Battery has to be in your backpack.... pretty small Motor..usually they are bigger.
Yeah Tongsheng Tsdz2 motor...it's 750 w just as powerful as Kenevo.
Battery is 450wh in the water bottle.
Yes, it is the Demo 29 DH bike. Specialized needs to make the Kenevo with that design and move on ftom the x wing. It is SOOO much better.
But they already have moved away from X-wing? Please check year 2020 model
no, it just like the Levo now. i doubt we will see an ebike based on the Enduro, there just isn't any room for the motor, as demonstrated here.
There are no changes for 2021 Kenevo. Apparently stock coming in in Nov/Dec is identical to this years model. Might just be an additional colour which europe had.
May be a complete work of fiction so can't be embargoed ?
Cockpit
StemDeity Copperhead, 35.0mm
HandlebarsRoval Traverse SL Carbon, riser bar, 6-degree upsweep, 8-degree backsweep, 30mm rise, 800mm, 35.0mm
GripsDeity, Knuckleduster, Black
SaddleBridge, 155/143mm, Hollow Ti-rails
SeatpostRockShox Reverb AXS, 30.9mm, S: 125, M:150, L/XL: 170mm
Brakes
Front BrakeMagura MT7, 4-piston caliper, hydraulic disc, 200mm rotor
Rear BrakeMagura MT7, 4-piston caliper, hydraulic disc, 200mm rotor
Drivetrain
Rear DerailleurSRAM XX1 Eagle AXS
CassetteSRAM XG-1299 Eagle, 10-52t
ChainSRAM XX1, 12 speed
Shift LeversSRAM Eagle AXS Rocker Paddle
CranksetPraxis Carbon M30, custom offset 160mm
ChainringsSRAM X-Sync Eagle, 104 BCD, 32t, steel
Wheels
Front WheelDT Swiss 29
Rear WheelDT Swiss 27
Front TireButcher BLCK DMND 29x2.6"
Inner TubesStandard, Presta valve
Rear TireButcher BLCK DMND 27.5x2.6"
E-Bike
MotorSpecialized Turbo Full Power System 2.2 Motor
BatterySpecialized M3-700, Integrated battery, 700Wh
ChargerCustom charger, 42V4A w/ Rosenberger plug
Ui/RemoteSpecialized MasterMind TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, w/Handlebar remote
Wiring HarnessCustom Specialized wiring harness
Frameset
Frame
FACT 9m Carbon w/ M5 alloy rear triangle
29" front wheel, 27.5" rear wheel, full internal cable routing, 148mm spacing, fully sealed cartridge bearings, 180mm of travel, geo adjust head tube, geo adjust horst pivot
ForkFOX FLOAT 38 Factory 29, Grip2 damper, 44mm offset, HSC, LSC, HSR, LSR, 110x15mm, 1.5" tapered steerer, 180mm travel, Kashima
Seat BinderAlloy, 38.6mm
Suspension
Rear ShockFOX FLOAT X2 Factory, LSC, LSR, 2-position lever, Kashima
    668K
