May be a complete work of fiction so can't be embargoed ?
Cockpit
Stem Deity Copperhead, 35.0mm Handlebars Roval Traverse SL Carbon, riser bar, 6-degree upsweep, 8-degree backsweep, 30mm rise, 800mm, 35.0mm Grips Deity, Knuckleduster, Black Saddle Bridge, 155/143mm, Hollow Ti-rails Seatpost RockShox Reverb AXS, 30.9mm, S: 125, M:150, L/XL: 170mm
Brakes
Front Brake Magura MT7, 4-piston caliper, hydraulic disc, 200mm rotor Rear Brake Magura MT7, 4-piston caliper, hydraulic disc, 200mm rotor
Drivetrain
Rear Derailleur SRAM XX1 Eagle AXS Cassette SRAM XG-1299 Eagle, 10-52t Chain SRAM XX1, 12 speed Shift Levers SRAM Eagle AXS Rocker Paddle Crankset Praxis Carbon M30, custom offset 160mm Chainrings SRAM X-Sync Eagle, 104 BCD, 32t, steel
Wheels
Front Wheel DT Swiss 29 Rear Wheel DT Swiss 27 Front Tire Butcher BLCK DMND 29x2.6" Inner Tubes Standard, Presta valve Rear Tire Butcher BLCK DMND 27.5x2.6"
E-Bike
Motor Specialized Turbo Full Power System 2.2 Motor Battery Specialized M3-700, Integrated battery, 700Wh Charger Custom charger, 42V4A w/ Rosenberger plug Ui/Remote Specialized MasterMind TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, w/Handlebar remote Wiring Harness Custom Specialized wiring harness
Frameset
Frame
FACT 9m Carbon w/ M5 alloy rear triangle
29" front wheel, 27.5" rear wheel, full internal cable routing, 148mm spacing, fully sealed cartridge bearings, 180mm of travel, geo adjust head tube, geo adjust horst pivotFork FOX FLOAT 38 Factory 29, Grip2 damper, 44mm offset, HSC, LSC, HSR, LSR, 110x15mm, 1.5" tapered steerer, 180mm travel, Kashima Seat Binder Alloy, 38.6mm
Suspension
Rear Shock FOX FLOAT X2 Factory, LSC, LSR, 2-position lever, Kashima
