I have great deal of respect for you. Your suspension knowledge is awesome. I made a suggestion that you could use that knowledge to help some of the other members get more out of their suspension set ups, instead of holding it over their heads that they didn’t know anything. You responded with a quiz. I was again impressed with your knowledge.
You don’t like the Butcher tire. I didn’t take it personal at all. It doesn’t work for you, it won’t work for everybody. Maybe it just works for me. It works for me and maybe something will come along that works better. That will be an awesome day. I like when things work better.
If you had understood the point I was trying to make as
@Stumpy had, you wouldn’t have felt it necessary to make that comment. Sorry if I pissed you off or offended you.
But since you wish to go there, let’s start with your first couple of statements.
“That’s why i called out the dirt i have issues with it in. Also stated I’ve never used oneon the rear. I have a lot of dampening in my forks, more then double what comes in any fork on the market as i prefer my forks to work more linear then the endustry standards of using tokens to hold your fork up, or keep it from bottoming i also find that wide block knobs on hard surface with loose pee gravel on top cause the tire to roll on the top of the knob.”
I know my grammar isn’t exactly scholarly, but let me help you out a bit, to make this a little easier to understand.
That’s why I described the conditions that give me issues with that tire. I also stated that never used one on my rear wheel. I have a lot of damping (not dampening. Surely the suspension master would know this) in my fork setup, more than (then is a time) double what comes stock on every fork on the market (did you check every fork on the market?) I prefer my forks to work more linear than (then is a time) the industry standard (Really? No one can agree on a bottom bracket standard or even a headset standard, but all of the fork makers agreed on tokens? Even the fork makers that don’t use them?) of using tokens to hold your fork up, or keep it from bottoming. In my experience, wide block knobs on a hard surface with loose pee gravel on top can cause the tire to roll on the top of the knob.
“I also really enjoyed my slaughter on rear until it rained and the ground got muddy.”
Must have been all that double dampening from your fork
