Without.
To be honest those two mud guards will do next to nothing apart from maybe rub the paint off your frame. As much as I dislike the look of mud guards its all out or don't bother.
I've got an RRP Proguard bolt on and I rate that on the front but don't bother with anything on the rear.
RE the RRP bolt on. I like that idea, but could not find where I was going to bolt anything to my RS Yari fork. Can you enlighten me about how they bolt on?Without.
I fitted a near a identical mud guard to you on my rear and it did pretty much nothing except rub my paint, I did notice that Mucky Nutz have this:I fitted 1 front an rear, I have always run a small 1 in the front an it has always worked well enough for me so I thought I’d try a rear 1 but to be honest it does not stop anything. I don’t mind the look so have left it there for now View attachment 28338
Ahh they don't currently fit Rockshox because there are no threaded holes on the fork brace, my bad. You could drill and tap a thread if you're feeling brave or just order the non bolt on version.RE the RRP bolt on. I like that idea, but could not find where I was going to bolt anything to my RS Yari fork. Can you enlighten me about how they bolt on?
And Steve above .. WOW !! where the heck are you riding - LOL! Now THAT is MUD !![]()
Seat tube mounted rear guards are incompatible with a dropper post.Well obviously it looks better without mudguards.
Your choice is unobtrusive, and I really like that, but I wouldn't call it a mudguard! It is more of a splashguard. If you come across any real mud it will clog very quickly, mud like this for example: (and yes, that is a stick in there!)
I would go for a seat tube mounted mudguard, like this:
MTB MUDGUARDS - 700 MTB Rear Mudguard
It has the great advantage of being not only cheap, but it will fit any diameter seat tube, wheel diameter, or suspension travel. And it absolutely will not clog! Brilliant design, not as unobtrusive as yours, but wayyyyy more effective!
They work and I wouldn't be without one! When I left mine laid on my tow bar rack subsequently to go missing during the drive home, I immediately bought another.
Unless the part of the dropper post that slides into the seat tube has sufficient length exposed to clamp on to.Seat tube mounted rear guards are incompatible with a dropper post.
How else do you think I did it?![]()
Tried that; I have too much suspension travel to mount the mudguard that low. You must have less suspension travel, a very high saddle position, a steeply angled mudguard, or a combination.Unless the part of the dropper post that slides into the seat tube has sufficient length exposed to clamp on to.
To tell you the truth I’m a fan of shot with the mudguard, it’s discreet and I like that, would I be right in saying it’s a front mudguard mate.
I have 150mm travel. The mudguard is positioned to avoid the tyre when the suspension is used, if I don't, the tyre moves it for me!Tried that; I have too much suspension travel to mount the mudguard that low. You must have less suspension travel, a very high saddle position, a steeply angled mudguard, or a combination.
I did something very similar to my Decoy. It changed my post-ride clean up from 30 min to 5 minutes. Getting all that crud that gets flung into the linkage was a pain.I've been running this dinky one in the back for a while mainly to stop the build up of crap than protect my back, that's what decent riding gear is for. Smallest cheapest one I could find. Had to clearance the chain side.
View attachment 28755 View attachment 28756 View attachment 28757
Thats with the original 2.8, now only switching between 2.5 or 2.6's in the back, so even more room.
