Coil Shock for 2015 Haibike XDuro Nduro Rx
Russ2550
33
US
Has anyone been able to fit a coil shock into the Haibike Xduro Nduro models? I was wondering if the back sweep to the lower end of the shock would cause an issue due to the spring. I don’t see much change from the 15’ to newer models on the around the rear Shock but I could be wrong. Any info would be appreciated!
Keggie
82
52
Suffolk
Hi
a coil will only fit on a Bosch model and not on a Yamaha they have a slightly different rear triangle and suspension set up.
Russ2550
33
US
Hi
I have the Bosch model that’s good to know. I just can’t remember ever seeing a Haibike with a coil on the Internet but I’m sure it’s out there. Thanks for the response!
Keggie
82
52
Suffolk
cushy!
20180211_101944-jpg.526
524K
