Running eco like that will it feel like I lower powered version of the Bosch on EMTB mode?
Pretty much yes. If your fairly fit you shouldn’t need to pop into trail as much
Will tell you when mine arrives this week. I spent a day on the alloy last week.Any Comp SL owners, or anyone who’s tested the alu Comp next to the Comp Carbon? Do they sound any different? I’m wondering if the different frame materials attenuate the sound differently.
Erm.., we don't have mountains in Austria?
Grossglockner is the highest mountain in Austria and the highest mountain in the Alps east of the Brenner Pass.Erm.., we don't have mountains in Austria?
Elevation: 3,798 m (12,461 ft)
So just under 3 times higher than anything in the UK.......
Any shops doing any amazing deals on the SL yet ?
curious - can you confirm which fork the expert has? Does it have the GRIP damper and the EVOL airspring?
NVM -i see the post above confirming it's a Performance
Doubtful. Most likely they are shimming the Reverb AXS because it only comes in 30.9mm.It’s just been pointed out to me that the Expert seatpost is 34.9mm, but the S-Works is 30.9mm. I’ve checked them all, and only the S-Works and Founders are 30.9mm.
Would this indicate that they have slightly different frames?
Need to call the shop tomorrow and check which Reverb they ordered me! Based on the price match, I reckon they’ve gone with the 30.9mm... as the 34.9mm was £30 cheaper.
Pictures posted looked like GBErm.., we don't have mountains in Austria?
Don't mind.Pictures posted looked like GB
AXS dropper comes in 30.9mm, 31.6mm and 34.9mm.Doubtful. Most likely they are shimming the Reverb AXS because it only comes in 30.9mm.
Why to choose the AXS instead of the X-Fusion? Isn´t the AXS much heavier?
These are NOT for the SL.I contacted Praxis direct about these last week. Response yesterday...
“These cranks are not yet available for the aftermarket. We should have these cranks by late spring or sooner. I’ll add you to the newsletter, so you’ll be notified when they are available.”
My LBS is away to try and order direct from Specialized.
About 50g heavier... but it’s the best dropper out there.
Used it before, and wouldn’t go back to a wired one!
No... the XX1 AXS is lighter than the XX1 manual version.Isn’t the whole axs system heavier than normal?
must be beneficial not having to faff about with the cable routing in an ebike frame.
Will be interesting know the weight of shifter, cable and derailleur. Even if just for GX. I mean is the weight of a cable similar to battery?
