Binned the huge hugger,I hated it,so decided to sort a solution.
First off I got some smaller tyres, pair of high rollers in 2.3 as they were on offer and ideal for muddy wet conditions.
Lots of clearance now front and rear.
Used a fork mudguard and then cut some tube and attached that to the 2 small bolts on the motor casing.
Fitted my fork splash shield which I prefer to a huge mudguard.
View attachment 26011View attachment 26012View attachment 26013
That's not great for a product designed to protect the bike.I need a bit of help here, I've mounted a SICOMTB Mudguard V2 on my Levo Comp 2020. However, its getting worse, the gravel is bombarding the lower swing, see attached pictures. I am not impressed with the Mudguard so far...any help or suggestions to mitigate this issue?
Cheers GregView attachment 30808
After looking at a few options for the Levo 2020 with 2.6 tyre and found that it was not that easy to fit a mud guard and one that have good coverage I installed the Carbon effect sicomtb rear mud guard.Thanks for recommendation. Still not sure it will fit 2020 with 2.6 rear
View attachment 19111less than 5mm clearance without mud n crud
Take Scotchguard 3M oder SlapperTape to protect those areas.
Greetings from germany
Cheers GregView attachment 30808View attachment 30809
#was supposed to be painting but couldn't be arsed ...
What are the front lights ? They look very "insecty" .. @Beekeeper would like the look of them.
sorry for the delay in reply buddy the lights are by an Australian company called ay-up lighting I have had them approx 8 years and they still run like new absolute amazing I have 3 sets you can even have them flashing and with blue and red caps it looks like I’m a copper from behind lol
found a A4 sheet of 2mm rubber... cut it out to fit .. only problem is finding double sided tape that is strong enough ....That looks good! What material and how did you attach it?
MY first attempt ...
1 muddy ride and 1 loam ride and it has worked a charm... nothing got in under the flap . Rather pleased with the result.
Got the idea off this forum, can't remember who but thank you in nonetheless.
I did something similar mainly as a test after I got a small rock stuck in the pivot point. I used a piece cut out of an old tire with a strip of Gorilla tape at the top. It doesn't look near as clean as your design, but it had the same result of nothing getting under the flap. IMO this is a great approach. Now I'm going to have to do another version that looks even half as good as yours.MY first attempt ...
I did something similar mainly as a test after I got a small rock stuck in the pivot point. I used a piece cut out of an old tire with a strip of Gorilla tape at the top. It doesn't look near as clean as your design, but it had the same result of nothing getting under the flap. IMO this is a great approach. Now I'm going to have to do another version that looks even half as good as yours.![]()
Like that idea.. you can take it off when you need to.. for any particular reason
what sticker is that ?Granted it’s. 2019, but I have a 2.6 Eddie Current on and it’s fits just fine.
