Levo Gen 2 2020 Turbo Levo Owners Thread
Just fitted invisiframe matte protection kit for my matte black levo.
3,5hours of total pain in the ass :LOL:
Actually pretty easy job.
Yeah same here, now I just need to find a rear mudguard that actually fits and doesn't cost £55.
I found some of the areas already a decent film on so I skipped them like the chainstay bridge and seat post.
I didn't remove any of the exiting tape either, but I doubled up as the tape that came on the bike felt thicker, but the invisiframe covered more area.
I know it said it wasn't recommended, but I liked the idea of having extra protection on the underside of the downtube and the back of the seat post.
You guys were quick!
Took me almost a day! I also missed out the duplicates apart from the downtube - extra protection.
A time consuming but satisfying job to me.
My thoughts exactly, it all stuck perfectly well so 2 is better than 1 right?
Thinking about using the matte kit on my battleship grey 2019 comp...any thoughts?
Take gloss if the paint isn’t matte.
Why? I can see using gloss if I want it to be invisible but a toned down Matte Battleship Grey might look nice with a few glossy bits that don't get covered by the invisiframe kit. Has anyone tried it???
Fitted also XT 8120 brakes with XT rotors.
Also avs handquards.
This decal looks very nice, what you have done with original Speicilized labels or are less visible due to being behind invisiFRAME?
The original spesh decals are really hard to see on mine under the invisiframe.
Some people don't like matt finish, unfortunately with Levo, we don't have much choice regarding nice colors. Putting glossy frame protection and transform mat finish is not a bad idea, especially for people that just can't get over matt finish, like me.... :p
Chameleon Skin with custom parts to fill some gaps and missing parts, like top of downtube.
That looks sweeeeet af. Not keen on any of the 2020 Levo colours. But that looks bad ass with the gloss!
Thanks. Now you can not tell that is Matt, if you don't get really up close.
We pay for this bikes almost, as much as a small new car. At least they could do, is give us an option, choosing colors, like in car industry or hire more competent person in charge of this department. :cautious:
View attachment 24225View attachment 24226
Looks spot on in the gloss look if you ask me ? i like what orbea are doing. Choose your own colour combo.
Been thinking to fit cc db coil IL shock to my levo.
Anyone has it, how it rides?
So the size is 210*55, but wich model is correct? The one rhat has 14,7mm end eye or the one wich has 15mm end eye?
what is the pushing size at the top?
WOW - What kind of range increase have you noticed running those tires, are those 2.6" ? I image with high pressure they would have very low rolling resistance.
This are 2.25 Vittoria.
I had similar tires, Continental 2.2 Speed King on my 20kg 2019 Levo, with 500Wh battery.
I manage to do around 120 km and 1.200m vertical elevation, with 15% assistance, on the road of course.
With 700W this would be probably around 160-170km, if you could manage. I can't....:LOL:
Is there an off the shelf 27.5 rear wheel that would fit a 2020 levo, eg from an earlier model or Kenevo?
I have a question RE the rockshox lyrik and select+ setup.
For reference I have a stumpjumper with fox suspension running 90psi/200psi F/R
I am about 75-80kg with gear on.
I put 100psi/200psi F/R in the levo, sag at 25% both ends, and found that I am bottoming out both really easily. Every run on a local trail, with some jumping /dropping 4 feet or something, the o rings were right at the top of the travel on the front and rear.
Today I tried 110psi/210psi F/R and the fork feels quite harsh, I don't think my hands can stand it for long.
I understand I can add volume spacers, but I am surprised I have to. I am a medium sized guy and am only working the suspension moderately, I have not gone full extreme on the levo (yet). I am seriously concerned if I do, I would damage the suspension with big drops to flat etc
Has anyone had similar issues?
I like what you have done, its a "SuperMoto" Levo. I have been looking at the Vittoria Mezcal for better street performance but still retaining some off road capability.
I forgot about SuperMoto, that would be spot on reference.;)
My friend got Vittoria Mezcal for his 2020 levo and exactly the same purpose, that you are thinking. Sweet spot for street use and also some light offroad. Continental Race king 2.2 is another option. Did have them on my previous Levo.
http://shrani.si/f/1B/3F/2HeJ8ckA/turbo-6.jpg
Yeah the Lyrik Select damper is average and doesn't offer any support to the air side at all so it means if you ride aggressively you need to stuff the fork full of tokens and run quite a bit of pressure to get it to cope with the bigger hits. I'm 88kgs and ran with 110psi with 4 or 5 tokens. The downside to that is it is harsh in all other conditions. .
Replacing the damper with the RC2 will help a little. Fitting the Push HC97 compression valve apparently helps a lot. Shockcraft in NZ can modify the damper to help too. In the end I replaced the fork with a Manitou Mezzer which has been sensational.
    Join 43,180
