Levo Upgrades in what order?
galaga187
795
596
Wroughton
I’m thinking of upgrading bars, fork, rear shock and wheels on my 2019 Levo Comp Carbon overtime. I can’t afford to do it all at once so was wondering what’s the best order? I want to upgrade for bigger days out on more challenging terrain.
ifu03558
80
71
Glasgow
Whats the problem with the existing components? When I'm changing parts on a bike its all about speed, will the new parts mean I'll be a bit faster downhill. Changing bars and wheels aint going to make you faster and I doubt they will hold you back on challenging terrain (whatever this means). I have same bike and I'm riding mostly steep stuff down Peebles including the dh runs at Inners etc and the suspension works well. Not really sure their is anymore challenging terrain in the UK than up my way to be honest. If you just fancy changing stuff as your cash rich fair enough, it wont make you faster though, better to spend the money on some coaching or just ride your bike more.
Blebo19
103
35
Italy
My upgrades:
Dtswiss hybrid h1700 27.5
Maxxis dhf dhr
Banger 2.0
Ashima disks
Galfer purple pads
Sram ex1 8v
Wolf thoot remote
Smp hybrid gel seat
Proimpact by andreani
Debonair 160mm kit
Specialized contour
Spank alu handlebar
H2off electric contacts protection
Nanotec frame shield
Nanotec lube
Alligator ptfe coated cable
34t alu crown
Xpedo spry magnesium pedals
galaga187
795
596
Wroughton
I did a coaching day last year with Katy Curd and it was excellent. My brief to Katy was I want to go faster safer and she delivered on that. I would be looking for the same with component upgrades. I will definitely be doing more with coaching next year.
galaga187
795
596
Wroughton
My upgrades:
Maxxis dhf dhr
Banger 2.0
Ashima disks
Galfer purple pads
Sram ex1 8v
Wolf thoot remote
Smp hybrid gel seat
Debonair 160mm kit
Specialized contour
Spank alu handlebar
Nanotec lube
34t alu crown
Thanks for sharing - did you do these in any particular order? Does the frame shield make the bike easier to clean?
escrs
283
260
Depends on what you feel would improve your riding the most, simplest upgrade is a new air shaft to take the forks to 160mm, cost around £50
My 2020 Expert is 2 months old and has the following upgrades so far
FOX Factory 36 160mm forks
FOX Factory X2 rear shock
FOX Factory Transfer dropper
Hope Fortus 30 27.5 wheels
Maxxis DHF and DHR2 tyres set up tubeless
Hope V4 brakes
Hope 155mm crank arms
Hope 36T chainring
DMR V12 pedals
Raceface Sixc carbon bars
Raceface Atlas stem
DMR DethGrips
Only original parts are the frame, motor, battery, brake discs, saddle, cassette, rear mech and shifter, these are the only original parts im currently happy with
Blebo19
103
35
Italy
I started with the 27.5 wheels +banger , the gel seat ,specialized contour ,neoprene mudguard and flat pedals.
With 27.5 it was really good with handlig but not too good in stability.
Then i understood it was too low on front side and i bought the 160mm kit installed with the proimpact kit with pleasure for my comfort and perfect balance of my bike handling and stability in dh.
Then i installed proimpact on the sock absorber and upgraded brakes.
I changed handlebar only for estetic.
After only 100km i broken a rear sprocket, so i upgraded to ex1 8v , i love it , i can change gear at any moment , during hard session and with high torque now.
Nanotec frame and rims protection is cool, i used the Wolfs Chemicals Nano Sealant Hard Body , i love it , nowit is easy to clean , and the product is durable.
Blebo19
103
35
Italy
Hope V4 brakes
Hope 36T chainring
DMR V12 pedals
Raceface Atlas stem
DMR DethGrips
How you feel with Hope 155mm crank arms?
Is this right HOPE Ebike Cranks 155mm Silver £156.99 ?
galaga187
795
596
Wroughton
Hope V4 brakes
Hope 36T chainring
DMR V12 pedals
Raceface Atlas stem
DMR DethGrips
@escrs thanks for sharing. Did you make all suspension changes at once? I upgraded to 36T a few weeks back and going much faster downhill.
Bryan Wells
120
140
Washington
Brakes, I went to XT's on the Expert and love them way more, I can hold wheelies for over a mile now and cant on the code r's simply because feathering is that much finer. Then maybe rear shock, I know everyone loves the dpx2... but the X2 is the better shock because of all of the adjustment ability. you really can make it feel just about however you want. lastly, a Lupine Headlight that is direct to the Levo motor power. Also you might want to tape the TCU so water can’t get in. Lastly, maybe some ice tech rotors because the will not scream at you and sound like trash when hard braking
Galion
99
119
Brazil
Upgrades on my Comp Carbon in this order:
Alu One up Pedals / ODI Rogue Grips
Levociraptor
Fox 36 Factory
Fox DPX2
2.5 DHF / 2.4 DHR
S-Works Carbon 3.8 bar / Deity Stem
Ergon SM E mountain Saddle
Aluminum dropper lever
The End....
escrs
283
260
pavelmatic
62
101
Lörrach, Germany
I love it, I couldn’t get my behind to adapt to the stock seat. The Ergon SME Mountain is well designed, great quality, comfort and looks. I am surprised there is not much talk about this seat. Rob seems to like it though.
+1 on that one! I have it on my (very short) wish list as the original Specialized is OK’ish but doesn’t provide much support on steep climbs. And thats even for a noobie like me...
Mattwilko92
229
188
Staffordshire, UK
How do you rate the Ergon saddle?
Running a WTB Volt at the moment which is ok, the stock Specialized one is horrible. But it purely slung on for the weight figure. Keep hearing good things about the Ergon.
dobbyhasfriends
🌹Old Bloke 🎸
3,212
4,585
Llandovery, Wales
that bloody seat was the first thing to go... replaced with a ergon ebike saddle then I put some higher rise renthal bars on.
The only things that stick out to me on the 2019 carbon are the wheels and fork, I would like to replace those over time but everything else is decent
thewrx
187
71
US
Magura MT7s brakes.
Cant have enough stopping power for a fast heavy bike!
Eddy Current tires just because you should.
New Saddle, yeah of course.
Pedals, stamps 7s for me.
And a lupiene light for xmas.
20,498
Interesting, although not sure if I’d want that thing sticking out my frame. The beauty of the much cheaper Levociraptor is that no one will know.
It's impressive that they've managed to put together an alternative TCU, but then again, maybe it's possible to use any third party Brose controller ? Does look a bit like something you'd put on temporarily whilst your configuring/testing. For anyone who rides like me (poorly :) ) I can imagine it soon getting torn off in a fall.
rodomotion
62
50
Chile
levo 2019 base model
my upgrades:
lyrik ultimate 160mm
shimano Zee brakes
maxxis assegai tires 2.5 (3C front , normal rear)
tranzx dropper 150mm.
