How to switch on?
Trickz
265
253
Burton upon Trent
Cheers chaps my first ebike and a bit green ATM??
looks like mine are all done,take it it’s just the three?
net wurker
185
237
Huntsville, AL USA
Hmmm, I may have mislead you. Try the drive-side cover. There is a big ole two-wire connector under one of them. I may have remembered which side it is in a wrongly way.
net wurker
185
237
Huntsville, AL USA
Agree?I take it the big fat one is the motor to battery connector and the other three are speed sensor display and the dreaded power button ?
Actually, check under the cover on the other side. Mine came with one of the covers off, and there was a big two-wire connector that was unplugged, I guess for shipping.
It wasn't like the one in your picture there.
net wurker
185
237
Huntsville, AL USA
Could it be that you just weren't charging it long enough to take it out of "factory sleep mode"?
On mine, whether I'm charging in the bike or out of the bike, the charger light and the battery light always go out once it's fully charged.
You had mentioned before about a light still being on after you charged?
20,504
Nothing this morning!
Have a new switch on its way over from Commencal.
Bugger ! So theoretically, if you charge the battery on the bike, it charges the battery in the switch at the same time. Maybe .... or it was just co-incidence ..
But in your case, it looks like you have a faulty switch battery so it's not holding power.
524K
