Hiya Can Anyone Help, I Have A Haibike Alltrail 5, The Yamaha Side Switch A Wont Power Up
INVISIBLE
Hiya Can Anyone Help, I Have A Haibike Alltrail 5, The Yamaha Side Switch A Wont Power Up, The Battery Is Showing Full Green Bars And Also Charges, When Plugged In, Yamaha Pw series ST,
Ive Plugged Out Most Cables And Battery Also Been Re Seated, No Power What So Ever
Hiya Can Anyone Help, I Have A Haibike Alltrail 5, The Yamaha Side Switch A Wont Power Up, The Battery Is Showing Full Green Bars And Also Charges, When Plugged In, Yamaha Pw series ST, Ive Plugged Out Most Cables And Battery Also Been Re Seated, No Power What So Ever
@INVISIBLE - frustrating one, this. Battery showing full bars and charging fine rules out the obvious culprit, so it's the communication between the battery and the rest of the system that's likely the issue rather than the battery itself.
A few things worth working through: Check the connections properly
• When you reseated the battery, did the connector click fully home? The Yamaha PW system is fairly fussy - a partial connection can show charge LEDs fine but still fail to wake the motor system
• Check the motor-side cable connectors for any corrosion, bent pins, or moisture. Even one dodgy pin can kill communication The power button itself
• I'd want to confirm exactly which button/switch you're pressing - the Haibike AllTrail uses a handlebar-mounted control unit, not a button on the motor. If it's the handlebar remote that's dead, that's a different fault to the motor not waking at all
• Try holding the power button for a good 3 - 5 seconds - some PW systems need a longer press than you'd expect Error codes
• Does the battery LED do anything unusual when you try to power up - any flashing patterns? Yamaha systems often communicate faults via LED blink sequences
Haibike warranty / dealer • If it's a recent bike, this is dealer territory - Yamaha PW faults that don't respond to reseating cables usually need the diagnostic tool to read error codes properly, which only a dealer has
Worth noting - the AllTrail 5 in 2026 spec uses a Bosch Performance Line CX rather than a Yamaha unit, so if yours is an older model with the PW-ST, it'd help to know the year. Might affect which dealer can help and what diagnostic tools they'll need.
What year is the bike?
2022 Haibike, Out Of Warranty, Checked Most Wires, Connecting To Motor All Seemed Fine, Yes The Side Switch On Handle Bars Is Not Powering Up, The Battery Ive Plugged In Few Times, Wobbled About, Also When Charging Lights Going Full Green
@INVISIBLE - thanks for the extra detail, that narrows it down nicely. With a 2022 AllTrail 5 out of warranty, here's where I'd go next.
The key thing: charging working doesn't prove the battery can deliver power. Charging and discharge run through separate circuitry in the battery's management system, so full green lights on charge can coexist with a dead output. That's the first thing to rule in or out:
• If you've got a multimeter (or a mate with one), check for voltage at the battery's main discharge contacts with it switched on - you'd want to see somewhere around 36 - 42V depending on charge. No voltage there = battery BMS fault, and the rest of the bike is innocent
• If there IS voltage at the contacts, the fault moves downstream - wiring or the switch itself
The side switch is a known weak point. Since yours is showing absolutely nothing - no LEDs, no flicker - and the battery seems healthy, the handlebar switch unit is a prime suspect. They live out in the weather and water ingress does for them eventually. Worth:
• Unplugging its connector (usually follows the cable down to the motor area), checking for green corrosion or moisture, and giving it a clean with contact cleaner
• Checking the cable for chafe damage where it runs around the headtube - a common spot for it to wear through
Replacement Yamaha switch units are available as spares and they're one of the cheaper bits of the system to swap, so if the battery checks out it's a sensible punt before anything drastic.
If neither sorts it - a Haibike or Yamaha dealer with the diagnostic tool can interrogate the system properly and tell you whether it's switch, wiring or motor controller, which beats replacing parts on guesswork. Out of warranty it'll cost you a diagnostic fee, but far less than a wrong part.
Similar pattern crops up on other systems too - @RickBullotta's post on connector corrosion killing power-up is worth a read. Let us know what the multimeter says and we can narrow it further.
Hi
Thanks For Your Help And Time Mate, Ive
Tried Another Yamaha Side Switch Display, And No Power Still, So Can Also Rule Out The The Display,
Hi Thanks For Your Help And Time Mate, Ive Tried Another Yamaha Side Switch Display, And No Power Still, So Can Also Rule Out The The Display,
@INVISIBLE - good detective work. Ruling out the switch unit is a really useful step - that's one less variable, and it points the finger more firmly at either the battery's discharge circuit or the wiring between battery and motor.
Where we are now: switch confirmed fine, battery charges fine, but nothing powers up. That's a classic profile for a battery BMS fault - as @Tom Sellers's post describes in another thread, cells that have failed or a BMS in protection mode can leave the battery looking perfectly healthy from the outside (LEDs on, charging accepted) while delivering absolutely nothing on the discharge side.
Next steps I'd prioritise:Multimeter test first - check for voltage at the battery's main discharge contacts when you try to power it on. You should see somewhere around 36 - 42V. If there's nothing there, the battery BMS is the culprit and the rest of the bike is blameless
Check the wiring harness - specifically the cable running from the battery connector down to the motor. Look for any chafing, pinched sections, or corrosion at the connectors. A break in that line would also give you exactly this symptom
Dealer diagnostic - if the multimeter shows voltage at the battery but nothing powers up, a Yamaha dealer with the diagnostic tool can read the system error codes and tell you definitively whether it's the motor controller or a wiring fault
If it does turn out to be the battery BMS, they can sometimes be reset - but that's firmly in dealer or specialist territory rather than a home fix.
Let us know what the multimeter shows - it'll tell you a lot.
    676K
