Alps Tour 2019
Just ordered this roof rack carrier, it has a max load of 23kg ?. Don't mind lifting it on top of the car as it's gives me a chance to some weight training?View attachment 17024
I’m sure this is a silly question but why take the battery out?
The roof rack is only rated to 20kgs, the levo expert is 21. With the battery out it’s 17ish. Also I have to lift the bastard above my head to get it on the car.I’m sure this is a silly question but why take the battery out?
I love this, does the bike sway much with the fork clamp?
Yeh it would work fine. My bike it 23kg with battery out and it holds fine. So your maths says you could have 3 bikes on your rack if wanted.Could you fit 2 of those bikes with a 2nd rack?
My hardtails are about 21kg with batteries off and max load for my SUV roof is 75kg
Last summer I drove the bike on a rack for 6000 km on my Alps trip and battery in. Sun, rain, heavy rain, wind, fog and everything works fineI think Spesh recommends the battery out when transporting.
Can I ask what rack that is in the back please?LWB VW Caddy, also my daily drive...
Decided a van type thing was the way to go. Currently popping front wheels off and securing to home made fork mounts. Like the idea of leaving the wheels on!
Cheers
Yep vans are the way to go... haven't looked back since getting the Caddy.
I also originally started carrying the Levo with front wheel off, but it was getting tiresome. It's OK with my road bikes but not with the eMTB so got this for carrying it with wheels on:
Front wheel in this, takes the 2.6" tyre, with a small amount of tape on the bolts to avoid scratching the rim:
Back wheel in this (probably optional if the bike is strapped down):
Then these to strap the bike down to the ringbolts in the floor:
15 - Cycling - 3m Straps, Twin Pack - Car Bike Rack Accessory
Sorry to revive this thread, i'd ask those that are exposing the carbon specy under the sunlight….on service manual specy says “Do not expose the bicycle to prolonged direct sunlight
How is that different to just riding it in the 38degC? At least on the car roof it has a faster cooling breeze.I was referring to transportation on roof one day under the sun and 38 degree Celsius
Same thing surely, the bike is either in the sun or it isn't. However, I guess that If I was to spend hours getting the bike to the trail head in hot sun, then OK, that means the bike gets extra UV vs what I get. Which was probably your point?Steve that makes sense about heating issues. But not about uv radiations and consequences .
