BHZ
BH's first in-house drive unit, the BHZ by SEG, is a Spanish-built lightweight motor that puts 65 Nm and a 500-watt peak into a 2.1 kg package, the heart of BH's iLynx Trail and Race Carbon SL e-MTBs.
Illustrative, not lab-measured: SL-class delivery in which torque builds quickly off low cadence, peaks across the mid-range and tails off smoothly toward the limiter, rewarding a brisk, steady cadence. No independent dyno trace has been published.
BH BHZ is the Basque brand's bold bet on going it alone. Rather than buying in a Bosch or Shimano unit, BH co-developed this drive with SEG Automotive and has it designed, developed and built at SEG's plant in Treto, Cantabria, making it one of the few genuinely Spanish-made mid-motors on the market. At 65 Nm of torque and 500 watts of peak power (250 W continuous, fed by a 36 V system) for just 2.1 kg, it sits squarely in the SL-class, the same lightweight bracket as Bosch's SX, Fazua's Ride 60, Specialized's SL 1.2 and the TQ HPR50.
The defining trait is naturalness. Three sensors, torque, speed and cadence, sample more than 1,000 times a second, so the assist arrives the instant you load the pedals and tapers cleanly toward the 25 km/h cut-off. BH quotes 100% power at all times regardless of battery charge across its Boost, Trail and Eco modes (with finer Trail+/Trail-/Eco+/Eco- steps in the app), so there's no over-eager surge and no lag, just a motor that amplifies the rider rather than replacing them. BH and the German press both flag it as one of the quietest units on the market, with no freewheel drag to spoil the descents, though no lab has yet published a decibel figure for it.
It is not, and was never meant to be, a 100 Nm full-power bruiser. On steep, technical climbs a Bosch CX (85 Nm) or Specialized 3.1 (101 Nm) will simply walk away from it. But for riders who want an e-MTB that rides like the analogue bike it's based on, the BHZ delivers the kind of light, lively, low-drag character that lets BH build a 120 mm trail bike that tips the scales at 17.8 kg while still carrying a 630 Wh battery.
Character
The case for and against
Strengths
- Genuinely lightweight at 2.1 kg
- Natural, instant, low-lag torque-sensor feel
- 100% motor power available at any battery charge
- Spanish-built (Treto, Cantabria) by SEG Automotive
- Pairs with a high-density 630 Wh battery (810 Wh with extender)
Compromises
- 65 Nm / 500 W can't match full-power rivals on steep climbs
- BH-exclusive ecosystem (app, display, battery, dealer service)
- No independent dyno, thermal or measured-noise data published yet
- Limited long-term field record so far
How it stacks up
Bikes running this motor · 40
