Bike Finder · BH
BH iLynx Trail
BH
iLynx Trail 2026
CurrentLightweight · TrailMature · 6.8/10iFreshness 6.8/10
Travel F/R
150/150mm
Wheels
29F / 29R
Frame
Aluminium / Full carbon
Weight
Price
From £3,200
View the BH iLynx Trail on BH’s site
BH iLynx Trail 2026
From £3,199
EMTB Forums verdict
The iLynx Trail is BH's mid-power trail platform, built around the in-house BHZ drive unit (a SEG Automotive motor rated at 65 Nm and up to 500 W) and a 630 Wh down-tube battery, with an optional 180 Wh XPro range extender. It sits below the full-power iLynx+ NX as the lighter, lower-torque option for riders who want a more natural-feeling assist on 29in wheels.
The range splits into alloy and HCIM carbon frames across two travel tiers. The 7.9, 8.0, 8.1 and Carbon 8.5 run 140 mm forks, while the 8.2, Carbon 8.7 and Carbon 8.9 step up to a 150 mm FOX 36. All builds share the Split Pivot suspension, 451 mm chainstays, a 66 degree head angle and a 75.5 degree seat angle through the four sizes, so the handling brief stays consistent as you climb the line.
Value is strongest in the middle of the range. The alloy 8.2 pairs the FOX 36 with SRAM DB8 four-piston brakes and a Shimano XT derailleur, while Carbon 8.7 adds the carbon frame, a FOX FLOAT X shock and 203 mm rotors. The flagship Carbon 8.9 moves to FOX Factory suspension, a fuller Shimano XT groupset and Race Face Turbine wheels. Entry alloy builds drop to Deore drivetrains and RockShox or SR Suntour forks, keeping the 7.9 close to £3,200.
Geometry read
Size
Descending
58
A solid all-round descender (66° head angle, 150mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
46
Size balance
87
Rear-long with a planted front in L (FC:RC 1.72) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
70
Climbs well — a 75.5° seat keeps the front planted. 500W of peak power and 65Nm of torque.
How it stacks up vs other Lightweight · Trail bikes (from 86 bikes in the database)
Battery630 Wh196 Wh above average
Motor torque65 Nmabout average torque
Value for money98/100from £3,200 · comparable bikes ~£4,999
Bike geometry diagram
SMLXL
Reach427 mm453 mm473 mm488 mm
Stack609 mm615 mm624 mm638 mm
Seattube420 mm430 mm440 mm480 mm
Chainstay451 mm451 mm451 mm451 mm
Headtube Angle66°66°66°66°
Seattube Angle (eff)75.5°75.5°75.5°75.5°
Wheelbase1177 mm1204 mm1228 mm1249 mm
Headtube95 mm100 mm110 mm125 mm
BB Height342.5 mm342.5 mm342.5 mm342.5 mm
Standover751 mm761 mm790 mm809 mm
Front Centre726 mm*753 mm*777 mm*798 mm*
FC:RC1.611.671.721.77
Trims · 7
7.9
£3,200
8.0
£3,700
8.1
£4,400
Carbon 8.5
£4,500
8.2
£4,800
Carbon 8.7
£5,500
Carbon 8.9
£6,800
MotorBH BHZ · 65 Nm · all trims
BatteryBH 630Wh · 630 Wh · all trims
Travel F/R150/150 mm · all trims
FrameAluminiumAluminiumAluminiumCarbonAluminiumCarbonCarbon
ForkSR Suntour XCR34 Air 140mm 15QRRockShox Recon RL Air 140mmFOX 34 FLOAT Rhythm 140mm 15QRRockShox Recon RL Air 140mmFOX 36 FLOAT Performance 150mm 15QRFOX 36 FLOAT Performance 150mm 15QRFOX 36 FLOAT Factory 150mm 15QR
ShockRockShox Deluxe DebonairRockShox Deluxe DebonairFOX FLOAT DPS PerformanceRockShox Deluxe DebonairFOX FLOAT DPS PerformanceFOX FLOAT X PerformanceFOX FLOAT X Factory
HeadsetAcros AIF-560 ICR BL · all trims
StemBH Evo 35 Fit · all trims
HandlebarRace Face Aeffect Riser 35 780mm · all trims
GripsErgon GE10Ergon GE10Ergon GE10Ergon GE10Ergon GE10Ergon GE10Ergon GE1-Factory
SaddlePrologo Proxim W350 StnPrologo Proxim W350 StnPrologo Proxim W350 StnPrologo Proxim W450 StnPrologo Proxim W450 StnPrologo Proxim W450 StnPrologo Proxim W450 Stn
SeatpostKind Shock Kagei (dropper, 100mm on SM)Race Face DP Aeffect 31.6mmRace Face DP Aeffect 31.6mmRace Face DP Aeffect 31.6mmRace Face DP Aeffect 31.6mmRace Face DP Aeffect 31.6mmRace Face DP Aeffect 31.6mm
BrakesShimano MT201Shimano MT420 4-PistonSRAM DB8 4-PistonShimano MT420 4-PistonSRAM DB8 4-PistonShimano MT520 4-PistonShimano XT 4-Piston
Rear derailleurShimano Deore 10spShimano Deore 12spShimano XT 12spShimano Deore 12spShimano XT 12spShimano XT 12spShimano XT 12sp
CrankFSA 34T SB-165mm · all trims
ShiftersShimano DeoreShimano DeoreShimano DeoreShimano DeoreShimano DeoreShimano DeoreShimano XT
CassetteShimano CSM4100 10sp (11-46T)Shimano CSM6100 12sp (10-51T)Shimano CSM6100 12sp (10-51T)Shimano CSM6100 12sp (10-51T)Shimano CSM6100 12sp (10-51T)Shimano CSM6100 12sp (10-51T)Shimano CSM8100 12sp (10-51T)
ChainShimano HG54Shimano CNM6100Shimano CNM6100Shimano CNM6100Shimano CNM6100Shimano CNM6100Shimano CNM6100
DrivetrainShimano Deore 10sp; FSA 34T SB-165mm; Shimano Deore; Shimano CSM4100 10sp (11-46T); Shimano HG54Shimano Deore 12sp; FSA 34T SB-165mm; Shimano Deore; Shimano CSM6100 12sp (10-51T); Shimano CNM6100Shimano XT 12sp; FSA 34T SB-165mm; Shimano Deore; Shimano CSM6100 12sp (10-51T); Shimano CNM6100Shimano Deore 12sp; FSA 34T SB-165mm; Shimano Deore; Shimano CSM6100 12sp (10-51T); Shimano CNM6100Shimano XT 12sp; FSA 34T SB-165mm; Shimano Deore; Shimano CSM6100 12sp (10-51T); Shimano CNM6100Shimano XT 12sp; FSA 34T SB-165mm; Shimano Deore; Shimano CSM6100 12sp (10-51T); Shimano CNM6100Shimano XT 12sp; FSA 34T SB-165mm; Shimano XT; Shimano CSM8100 12sp (10-51T); Shimano CNM6100
WheelsBH Lite Mach1 Trucky 30Race Face Ar 30 TRRace Face Ar 30 TRRace Face Ar 30 TRRace Face Aeffect 30 TRRace Face Arc 30 TRRace Face Turbine 30 TR
TyresMaxxis Rekon TPI120 MaxxSpeed EXO TR 29x2.4Maxxis Minion TPI120 Terra EXO TR 29x2.5/2.4Maxxis Minion TPI120 Terra EXO TR 29x2.5/2.4Maxxis Minion TPI120 Terra EXO TR 29x2.5/2.4Maxxis Minion TPI120 Terra EXO TR 29x2.5/2.4Maxxis Minion TPI120 Terra EXO TR 29x2.5/2.4Maxxis Minion TPI120 Terra EXO TR 29x2.5/2.4
Price£3,200£3,700£4,400£4,500£4,800£5,500£6,800
Rides similarly
Spot a mistake?
