Bike Finder · BH
BH iLynx Race Carbon
BH
iLynx Race Carbon 2023
DiscontinuedLightweight · Cross-CountryLegacy · 1.6/10iFreshness 1.6/10
Motor
BH BHZ · 65Nm · 500W
Battery
BH 540Wh (XPro range-extender to 720Wh)
Travel F/R
120/120mm
Wheels
29F / 29R
Frame
Full carbon
Weight
Price
From £6,300
View the BH iLynx Race Carbon on BH’s site
BH iLynx Race Carbon 2023
From £6,299
EMTB Forums verdict
The 2023 BH iLynx Race Carbon was BH's lightweight XC and marathon race eMTB, sharing its HCIM monocoque carbon frame (Toray T1100 and T800 fibres, claimed 2,200g with shock) with BH's high-end road bikes. Power came from BH's own in-house 2EXMAG drive, a compact 2.1kg unit quoted at 65Nm and 250W and described by BH as 10 per cent lighter than the previous 2ESMAG, paired with a 540Wh internal battery that could be topped up to 720Wh via the optional XPro add-on pack.
The range spanned four trims. The LT models ran 120mm of FOX 34 travel: the LT 7.6 (Shimano XT mechanical, MT420 brakes, Race Face wheels) at GBP 6,299.90 and the LT 7.7 (Factory fork, XT brakes, alloy wheels) at GBP 7,299.90. The Pro LT 7.8 added Shimano XTR, FOX Factory and carbon wheels at GBP 8,299.90, while the flagship Pro 7.9 dropped to a 100mm race set-up with FOX Factory SC remote, SRAM XX1 AXS wireless shifting and the 720Wh battery for GBP 9,299.90.
Geometry was firmly XC-orientated for its era. The LT 7.6 and Pro 7.9 used a 67.7 degree head angle and 74.7 degree seat angle, while the LT 7.7 and Pro LT 7.8 ran a slightly steeper 68.5 degree head angle; chainstays were a short 453mm across all sizes, which spanned S, M and L only. This generation is now discontinued. BH later carried the iLynx Race Carbon name forward into a lighter 2025 and 2026 platform that rebranded the same in-house drive family as the 65Nm BHZ (built by SEG Automotive) and moved to a 630Wh battery.
Geometry read
Size
Descending
43
Steeper 67.7° and shorter travel — happiest descending smooth, flowy trail rather than properly rough or steep terrain.
Playfulness
51
Size balance
60
Not enough geometry on record to judge size balance.
Technical climbing
32
A workmanlike climber — expect to put in more rider effort on the steep stuff. 500W of peak power and 65Nm of torque.
Watch out forNot built for serious descending — happier on flow than in the rough and steep.
Fine at trail pace; it'll feel out of its depth on properly rough, steep tracks.
How it stacks up vs other Lightweight · Cross-Country bikes (from 63 bikes in the database)
Battery540 Wh104 Wh above average
Motor torque65 Nmabout average torque
Value for money50/100from £6,300 · comparable bikes ~£6,300
Bike geometry diagram
SML
Reach412 mm431 mm451 mm
Stack598 mm605 mm612 mm
Seattube400 mm440 mm480 mm
Chainstay453 mm453 mm453 mm
Headtube Angle67.7°67.7°67.7°
Seattube Angle (eff)74.7°74.7°74.7°
Headtube100 mm110 mm120 mm
Trims · 4
LT 7.6
£6,300
LT 7.7
£7,300
Pro LT 7.8
£8,300
Pro 7.9
£9,300
MotorBH BHZ · 65 Nm · all trims
BatteryBH 540Wh (XPro range-extender to 720Wh) · 540 Wh · all trims
Travel F/R120/120 mm · all trims
FrameCarbon · all trims
ForkFOX 34 FLOAT Performance 120mm 15QRFOX 34 FLOAT Factory SC 120mm 15QRFOX 34 FLOAT Factory SC 120mm 15QRFOX 34 FLOAT Factory SC Rem 100mm 15QR
ShockFOX FLOAT DPS PerformanceFOX FLOAT DPS PerformanceFOX FLOAT DPS FactoryFOX FLOAT DPS Factory Rem
HeadsetAcros AIF-543 ICR BL. · all trims
StemBH Evo 31 Fit · all trims
HandlebarBH MTB Lite Alloy Riser 780mmBH MTB SLite Alloy Riser 780mmBH Evo Carbon Riser 760mmBH Evo Carbon Riser 760mm
GripsErgon GE10Ergon GE1-FactoryErgon GE1-FactoryErgon GE1-Factory
SaddlePrologo Proxim W350 StnPrologo Scratch M5 StnPrologo Scratch M5 StnPrologo Scratch M5 Stn
SeatpostRace Face DP Aeffect 31.6Bike Yoke Divine 31.6Bike Yoke Divine 31.6BH Evo Carbon 31.6
BrakesShimano MT420 4 Piston (front and rear)Shimano XT 4 Piston 203mm (front and rear)Shimano XT 4 Piston 203mm (front and rear)Shimano XT 4 Piston 203mm (front and rear)
Rear derailleurShimano XT 12spShimano XT 12spShimano XTR 12spSram XX1 AXS Eagle 12SP
CrankFSA 34T-165mmFSA 34T-165mmFSA Carbon 34T 165mmFSA Carbon 34T 165mm
ShiftersShimano DeoreShimano XTShimano XTSram XX1 AXS Eagle
CassetteShimano CSM6100 12sp (10-51T)Shimano CSM8100 12sp (10-51T)Shimano CSM8100 12sp (10-51T)Sram XX1 Eagle 12sp (10-52T)
ChainShimano CNM6100Shimano CNM6100Shimano CNM6100Sram XX1 Eagle
DrivetrainShimano XT 12sp; FSA 34T-165mm; Shimano Deore; Shimano CSM6100 12sp (10-51T); Shimano CNM6100Shimano XT 12sp; FSA 34T-165mm; Shimano XT; Shimano CSM8100 12sp (10-51T); Shimano CNM6100Shimano XTR 12sp; FSA Carbon 34T 165mm; Shimano XT; Shimano CSM8100 12sp (10-51T); Shimano CNM6100Sram XX1 AXS Eagle 12SP; FSA Carbon 34T 165mm; Sram XX1 AXS Eagle; Sram XX1 Eagle 12sp (10-52T); Sram XX1 Eagle
WheelsRace Face Ar 30 TR wheelset (BH hubs, stainless steel spokes)BH Evo A30 Alu TR wheelset (BH Evo hubs, stainless steel spokes)BH Evo C30 Carbon TR wheelset (BH Evo hubs, stainless steel spokes)BH Evo C30 Carbon TR wheelset (BH Evo hubs, stainless steel spokes)
TyresMaxxis Ardent/Ikon TPI120 MaxxSpeed EXO TR 29x2.35Maxxis Ardent/Ikon TPI120 EXO TR 29x2.35Maxxis Ardent/Ikon TPI120 EXO TR 29x2.35Maxxis Ardent/Ikon TPI120 MaxxSpeed EXO TR 29x2.35
Price£6,300£7,300£8,300£9,300
Rides similarly
Spot a mistake?
