Thanks,On the older PW-X system it was a code for a battery fault;
Though the controller mentioned is as far a I know actually part of the motor :^(
@Bearing Man ?
Hi, does anyone know what the error code 73 means on a Yamaha PW - ST motor with the Yamaha display A. It powers on for a few seconds with the display code, then goes off. Thanks.
Hi did you manage to find the problem? Mine has started showing this error code and I have replaced the control unit and the battery... worked fine for about 5 miles now the fault is intermittentHi, does anyone know what the error code 73 means on a Yamaha PW - ST motor with the Yamaha display A. It powers on for a few seconds with the display code, then goes off. Thanks.
I have replaced the battery and control unit on mine which fixed the fault for about 5 miles now its back, I need a part number for the battery connection on the bike??According to manual it is "overcurrent" but as with all 7x codes, it is a battery problem.
I think I have solved it on mine. It seems to be a connection issue between engine and the battery. My (intube) battery has four very small holes and I guess it has a bit oxidation. Adding CRC or TF2 seems to help a bit, but I still get sometimes the error. It is better as on last monday it did not start for a full day (15km).
All you who remove sometimes the battery, take good care of your interface to avoid buying a new battery.
Hi, yes I took it to the dealer and they tested it and found the motor had gone. Luckily it was still in warranty and was replaced no problem.Hi did you manage to find the problem? Mine has started showing this error code and I have replaced the control unit and the battery... worked fine for about 5 miles now the fault is intermittent
